Improved Functional Coverage with Dynamic Arrays
Is there a way to run test dynamically changing the constraints according to the functional coverage?
To test my block I use a set of random-constrained test, able to set the functional coverage to roughly 98%.
To reach the 100% I need everytime to relaunch singularli some of those tests fixing some specific testbench variables that I know.
It’s not a bit deal but I’d like to automatize this flow, checking the uncovered bins and launching specific tests and sequences
constraining the tb variables accordingly.
I don’t have a clear idea on how to do this, I read that PPS can be a good solution, but I am not an expert.
What kind of approach is generally adopted in this situations?
In reply to giulio95:
This question is the Holy Grail of Functional Coverage. If you were using assertions, a formal tool can trace through the design and exhaustively prove that the assertion is valid or not. But given a testbench, it can be next to impossible to figure out what stimulus needs to change to hit a functional coverage point.
Some are experimenting with machine learning algorithms to see if there is anything that could be done to the constraints to improve coverage, but I would say that is mostly in the academic and design specific cases.
Some things that I would suggest is looking at your coverage models and making sure you are not over-specifying your bins(like trying to cover an entire address space) and looking at formal analysis in certain areas to achieve functional coverage rather than dynamic simulation.
Hi Dave,
Thanks for the super useful answer.
On the theoretical level I know what is formal analysis, but on the practical side I have never built a formal setup myself. Do you have any good documentation to read? Do I need to simply write assertions to cover the states specified by the bins?
What about graph-based stimuli to improve my functional coverage?
