Imported package not found
Hi All,
I was working on APB template. I created a basic package for test class like this:
package apb_test_pkg;
    	`include "uvm_macros.svh"
	`include "tb_defines.sv"
	`include "apb_base_test.sv"
endpackage: apb_test_pkg
and imported this package in top module like this:
module tb_top();
   	 import apb_test_pkg::*;
	bit clk_100MHz;
	apb_interface apb_intf(clk_100MHz);
			#((0.5/`APB_CLK_FREQ) * 1s) clk_100MHz = ~clk_100MHz;
	apb_design DUT (
			.PRESETn(apb_intf.PRESETn),
			.PCLK(clk_100MHz),
			.PSEL(apb_intf.PSEL),
			.PENABLE(apb_intf.PENABLE),
			.PWRITE(apb_intf.PWRITE),
			.PADDR(apb_intf.PADDR),
			.PWDATA(apb_intf.PWDATA),
			.PRDATA(apb_intf.PRDATA),
			.PREADY(apb_intf.PREADY),
			.PSLVERR(apb_intf.PSLVERR)
		uvm_config_db#(virtual apb_interface)::set(null,"*","APB_INTF",apb_intf);
		run_test();
but i am getting following error
**# ** Error: …/tb/tb_top/tb_top.sv(7): Could not find the package (apb_test_pkg). Design read will continue, but expect a cascade of errors after this failure. Furthermore if you experience a vopt-7 error immediately before this error then please check the package names or the library search paths on the command line.
** Error: C:/questasim_10.2c/win32/vlog failed.**
If instead of importing the “apb_test_pkg” if i simply include all files of this package in top module it will work. since i already added path of this package in run script but still facing same error, could you guys help me to understand why it is so?
Aaditya Vishal Soni
In reply to AadityaVS:
You need to make sure you’ve compiled the package before importing it.
This is most likely a tool usage issue, and this forum is not for tool specific issue.
Compile clean the package first.
Hi Dave,
Its working now, Thanks
