Implementation issue: uvm_config_db method wait_modified
Q. Why doesn’t the control come out of wait_modifed method?
interface chip_intf;
   logic [7:0] lvds_clk_p;
   wire  [7:0] gpio;
   logic       rowsel0, rowsel256;
   logic       precharge0, precharge256;
   reg 	       gpio11_ind;
   bit   [6:0] frm_row_end_t;
       initial
               $display($time," - Waiting to receive RE\n");  // Gets displayed
               uvm_config_db#(bit[6:0])::**wait_modified(null,"*","RE");**
               $display($time," - Received RE value\n"); // time stamp and info not getting displayed
               if(!uvm_config_db #(bit[6:0])::get(null, "*", "RE",frm_row_end_t))
	              `uvm_fatal("Chip Interface", "Could not find frm_row_end_t \n")
               $display("The value of frame_row_end = %0d\n",frm_row_end_t);
endinterface
// ENV Class
uvm_config_db#()::set with a variable in the End_of_Elaboration_Phase of my_env extended from uvm_env;
In reply to Viral Doshi 2013:
There was a bug in versions prior to UVM 1.1d where wait_modified did not work if the set() had a wildcard “*”.
But a much more efficient way of waiting for your environment to be set up is to use the wait_for_state() method.
   start_of_simulation_ph.wait_for_state(UVM_PHASE_STARTED);
Thank you, Dave Rich.
The method wait_for_state worked.
Method 1: start_of_simulation_ph.wait_for_state(UVM_PHASE_STARTED); // Working*
So, did the normal wait_method worked
Method 2: uvm_config_db#(bit[6:0])::wait_modified(null,"",“RE”); // Working
In both cases* i.e. Method 1 and Method 2, use context only as NULL or uvm_root::get() while setting in ENV (as shown below):
uvm_config_db#()::set(null,““,“RE”,frm_row_end_t);
or
uvm_config_db#()::set(uvm_root::get(),”
”,“RE”,frm_row_end_t);
CAUTION
uvm_config_db#()::set(this,“*”,“RE”,frm_row_end_t); // Context as “this” will not work
