I want to write an assertion for checking that the data stable for 16 clock cycles and continue the checking for the next 16 cycles and so on.?How can i write this?
Hi, i am very much new to the topic and need help in understanding
I am writing an assertion where as long as tx_frame is high, it should check the data stable for 16 cycles.
i wrote something like this, but its not happening as needed.
a1: assert property (@(posedge tx_bclk) frame_check)
property framecheck
disable iff(rst || !tx_frame)
tx_frame |=> ($stable(uart_txd_o)[*16]);
endproperty
[waveform added]
In reply to adharshh:
This is what your assertion is doing. But uart_txd_o is not stable for 16 clock cycles. The red mark is showing you the 16.
My data is there for 16 cycles, but the checking somehow is starting one cycle after.
Is there any other way, instead of using $stable, to check the data stability?
You can use the local variable. $stable checkes previoud and current value to assure the data has not canged.
I belived when the tx_frame is high, the data will be available on uart_txd_o;
property framecheck
int local_data ;
(tx_frame, local_data = uart_txd_0) |-> (local_data == uart_txd_o)[*16]);
endproperty
You are using the non-overlapping implication operator which delays the counting by 1 clock cycle. That’s correct.
How about this one, its seems working.
property framecheck
int local_data ;
disable iff(!rst || !tx_frame)
(tx_frame, local_data = uart_txd_0) |=> (local_data == uart_txd_o)[=15]);
endproperty.
This property, take the txd_o value in the 1st baud clock and check it with the rest (with next 15 cycles) and so on.
There are always aeveral solutions. This should also work:
property framecheck
  tx_frame |-> ($stable(uart_txd_o)[*16]);
endproperty
I’m useing the overlapping implication operator. It starts counting when tx_frame is 1’b1.
I am not sure why, but the above one is not working.
when i give non_overlapping implication/ overlapping implication operator with $stable i am getting error one cycle after the toggles.
You will have to add a term to the antecedent on every change of uart_tx_o, otherwise your assertion would fire a cycle after every change of uart_txt_o
Try this:
property framecheck
  tx_frame && $change(uart_txd_o) ||-> ($stable(uart_txd_o)[*15]);
endproperty
property framecheck
int local_data ;
endproperty.
Not sure why you have used “[=15]” operator here. That is non-contiguous. From your waveform, you want to check the stability on 16 consecutive clock ticks right?
In reply to ledzep_1988:
Uart data bit may or maynot change after 16 baud cycles. i dont think the above assertion could meet the requirement. Thankyou.
