I am new to UVM.How can collect packet stored in a queue as a sequence in one by one manner and run over a sequencer in uvm? Sequence body is given,build phase of the sequencer is given with getting handle of component with queue.help to solve this
task body();
my_sequencer = get_sequencer();
ERROR_bad_ace_axi_pkt: assert (!($cast(axi3_pkt, ace_axi_pkt)));
`uvm_sent(ace_axi_pkt)
//Getting the ace_snoop_agent configuration object from environment inside axi3sequencer
if(!uvm_config_db #(ace_snoop_agent_cfg) ::get(this,“”,“ace_snoop_agent_cfg”,ace_snoop_agent_cfg_h))
`uvm_fatal(get_full_name(),“The sequencer didn’t get the ace snoop agent config object handle”)
In reply to nithya jinu:
Could you please show some more code to clarify your problem?
You do not store data packets(seq_items) on the generation side in a queue.
You are instructing your sequence to do this in a one-by-one manner when the processing of the actual packet has been completed.
You should do this in driver.
class t_driver extends uvm_driver #(packet);
  virtual intf vif_tb;
  static int txn_cnt;
  packet txn[$];
    @(vif_tb.cb); // Give one clock to allow propagation of clocking block
      drive_address(txn);
      `uvm_info(get_full_name(), "Driver got a sequence item", UVM_MEDIUM);
      txn.push_back(req);
      seq_item_port.item_done();
  task automatic drive_address(packet txn[$]);
