I’m trying to create an assertion check for whenever signal A changes from non_zero value to zero value, next cycle B should be stable for 5cycles. Thanks
In reply to chendhu:
Coulsd you please show what you are trying?
BTW assertion know only logic high or low.
Hi
I have two signals
[2:0] ctrl;
en;
If I randomized ctrl signal it generates 0 to 7 values, Whenever ctrl signal changes from non_zero value(1,2…7) to zero(0)value, Next cycle en should be high for 5 clock cycles.
I need to check above condition.Thanks
Try this,
property ctrl_en; (I assume its not a synchronous signal)
((ctrl==0) |-> ##1 $rose(en) [*5]);
endproperty
en_ctr: assert property(ctrl_en);
In reply to sai_pra99:
This wont work as $rose will not be repeated 5 times.
property cntrl_en ;
//clocking or infer the default clocking
(1,cntrl==0) |=> $rose(en) ##0 en[*5] ;
endproperty
