Thank you chr_sue,
The log you mentioned was old one, I attached new one at the previous post.
Here again the log
UVM_INFO hsio_reg_adapter.sv(30) @41000000: reporter [reg_adpater] reg2bus: addr = 00000000, data=12341234, kind=0
UVM_INFO hsio_reg_adapter.sv(55) @41000000: reporter [reg_adpater] reg2bus: addr = 00000000, data=0000000, kind=1
UVM_INFO hsio_reg_adapter.sv(30) @41000000: reporter [reg_adpater] reg2bus: addr = 00000004, data=fedcba98, kind=0
UVM_INFO hsio_reg_adapter.sv(55) @41000000: reporter [reg_adpater] reg2bus: addr = 00000004, data=0000000, kind=1
The adapter is
class reg_adapter extends uvm_reg_adapter;
`uvm_object_utils(reg_adapter)
function new(string name="reg_adapter");
virtual function uvm_sequence_item reg2bus(const ref ugvm_reg_bus_op rw);
hsio_seq_item tr;
tr = hsio_seq_item::type_id::create("tr");
tr.addr = rw.addr;
tr.data = rw.data;
tr.kind = (rw.kind == UVM_READ) ? 1: 0;
`uvm_info(get_type_name, $sformatf("reg2bus: addr=%h, data=%h, kind=%h",tr.addr, tr.data, tr.kind), UVM_LOW);
return tr;
virtual function void bus2reg(uvm_sequence_item bus_item, ref uvm_reg_bus_op rw);
hsio_seq_item tr;
if(!$cast(tr, bus_item)) `uvm_fatal(get_type_name(), "Fail to cast seq_item");
rw.addr = tr.addr;
rw.data = tr.data;
rw.kind = (tr.kind) ? UVM_READ : UVM_WRITE;
register_env is
`include "hsio_reg_adapter.sv"
`include "ral_hsio_cfg_regmodel.sv"
class hsio_reg_env extends uvn_env;
`uvm_object_utils(hsio_reg_env);
reg_dapater adapter;
ral_block_hsio_cfg_regmodel regmodel;
function new(sting name="hsio_reg_env", uvm_component parent);
adapter = reg_adapter::type_id::create("adapter", this);
regmodel = ral_block_hsio_cfg_regmodel::type_id::create("regmodel", this);
regmodel.build();
regmodel.deault_map.set_base_addr('h0);
regmodel.reset();
regmodel.add_hdl_path("TEST_TOP.....");
regmodel.lock_model();
regmodel.print();
uvm_config_db#(ral_block_hsio_cfg_regmodel)::set(null, "uvm_test_top","regmodel",regmodel);
super.connect_phase(phase);
top env is
class hsio_env extends uvm_env;
`uvm_component_utils(hsio_env);
hsio_agent hsio_agnt;
hsio_subscriber hsio_sub;
hsio_reg_env reg_env;
function new(string name="hsio_env", uvm_component parent);
hsio_agnt = hsio_agnet::type_id::create("hsio_agnt", this);
hsio_sub = hsio_subscriber::type_id::create("hsio_sub", this);
reg_env = hsio_reg_env::type_id::create("reg_env", this);
function connect_phase(uvm_phase phase);
hsio_agnt.monitor.item_collected_port.connect(hsio_sub.analysis_export);
reg_env.regmodel.default_map.set_sequencer(hsio_agnt.seqr, reg_env.adapter);
task of test class is
task ral_test::rrun_phase(uvm_phase pahse);
uvm_status_e status;
int data;
phase.raise_objection(this,"Start");
uvm_config_db#(ral_block_hsio_cfg_regmodel)::get(null,"uvm_test_top","regmodel", regmodel);
regmodel.CFG_U20H0_BCFG.write(status, 32'h1224_1234);
regmodel.CFG_U20H0_BCFG.read(status, data);
regmodel.CFG_U20H0_PCFG0.write(status, 32'hfedcba98);
regmodel.CFG_U20H0_PCFG0.read(status, data);
phase.drop_objection(this,"Finish");
phase.phase_done.set_drain_time(this. 50);
