How to wait for taking data from monitor number of clock cycles?
I am writing a UVM for processor and I am verifying the instructions so I have to check the data in the write back stage so woit for at least 5 clock cycles as the pipeline is 5 stage I am askig how to deal with that in my scoreboard or monitor ?
Scoreboard code
include "uvm_macros.svh" //include “processor_sequence.sv”
uvm_analysis_imp_decl(_mon_trans) uvm_analysis_imp_decl(_drv_trans)
class GUVM_scoreboard extends uvm_scoreboard;
// register the scoreboard in the UVM factory
`uvm_component_utils(GUVM_scoreboard);
//processor_transaction trans, input_trans;
// analysis implementation ports
uvm_analysis_imp_mon_trans #(processor_transaction,GUVM_scoreboard) Mon2Sb_port;
uvm_analysis_imp_drv_trans #(processor_transaction,GUVM_scoreboard) Drv2Sb_port;
// TLM FIFOs to store the actual and expected transaction values
uvm_tlm_fifo #(processor_transaction)  drv_fifo;
uvm_tlm_fifo #(processor_transaction)  mon_fifo;
endfunction : new
//Instantiate the analysis ports and Fifo
Mon2Sb_port = new(“Mon2Sb”, this);
Drv2Sb_port = new(“Drv2Sb”, this);
drv_fifo = new(“drv_fifo”, this,8); //BY DEFAULT ITS SIZE IS 1 BUT CAN BE UNBOUNDED by putting 0
mon_fifo = new(“mon_fifo”, this,8);
endfunction : build_phase
// write_drv_trans will be called when the driver broadcasts a transaction
// to the scoreboard
function void write_drv_trans (processor_transaction input_trans);
void’(drv_fifo.try_put(input_trans));
endfunction : write_drv_trans
// write_mon_trans will be called when the monitor broadcasts the DUT results
function void write_mon_trans (processor_transaction trans);
void’(mon_fifo.try_put(trans));
endfunction : write_mon_trans
processor_transaction exp_trans, out_trans;
bit [31:0] h1,i1,i2,imm;
//bit [19:0] sign;
drv_fifo.get(exp_trans);
mon_fifo.get(out_trans);
i1=exp_trans.RS1_data;
i2=exp_trans.RS2_data;
imm={{20{exp_trans.immediate_data[11]}}, exp_trans.immediate_data}; //IMMEDIATE VALUE SIGN EXTENSION
if((exp_trans.instrn[31:30]==2’b10 && exp_trans.instrn[24:19]==6’b000000 && exp_trans.instrn[13:5]==9’b000000000) ||(exp_trans.instrn[6:0]==7’b0110011 && exp_trans.instrn[14:12]==3’b000 && exp_trans.instrn[31:25]==7’b0000000 ) || (exp_trans.instrn[24:21]==4’h4 && exp_trans.instrn[27:26]==2’b00)) //LEON/RISCY/AMBER //ADD common
uvm_info ("ADD_INSTRUCTION_PASS ", $sformatf("Actual Instruction=%h Expected Instruction=%h \n",out_trans.inst_out, exp_trans.instrn), UVM_LOW) h1=i1+i2; if((h1)==(out_trans.reg_data)) begin uvm_info ("ADDITION_PASS ", $sformatf(“Actual Calculation=%d Expected Calculation=%d \n”,out_trans.reg_data, h1), UVM_LOW)
else
`uvm_error(“ADDITION_FAIL”, $sformatf(“Actual Calculation=%d Expected Calculation=%d \n”,out_trans.reg_data, h1))
  else if((exp_trans.instrn[31:30]==2'b10 && exp_trans.instrn[24:19]==6'b000000 && exp_trans.instrn[13]==1'b1) || (exp_trans.instrn[6:0]==7'b0010011 && exp_trans.instrn[14:12]==3'b000 )) //ADD IMMEDIATE INSTRUCTION
  `uvm_info ("ADD_IMMEDIATE_INSTRUCTION_PASS ", $sformatf("Actual Instruction=%h Expected Instruction=%h \n",out_trans.inst_out, exp_trans.instrn), UVM_LOW)
   h1=i1+imm;
					`uvm_info ("ADDITION_IMMEDIATE_PASS ", $sformatf("Actual Calculation=%d Expected Calculation=%d \n",out_trans.reg_data, h1), UVM_LOW)
					else
					`uvm_error("ADDITION_IMMEDIATE_FAIL", $sformatf("Actual Calculation=%d Expected Calculation=%d \n",out_trans.reg_data, h1))
  else
  `uvm_error("INSTRUCTION_ERROR", $sformatf("Actual=%d Expected=%d \n",out_trans.inst_out, exp_trans.instrn))
endclass : GUVM_scoreboard
Monitor code
include "uvm_macros.svh" include “processor_sequence.sv”
class GUVM_monitor extends uvm_monitor;
`uvm_component_utils(GUVM_monitor) // put monitor in a register in the uvm factory
virtual GUVM_interface GUVM_vif; // using virtual interface to monitor
uvm_analysis_port #(processor_transaction) Mon2Sb_port; // analysis port to scoreboard to sendd transactions
function new(string name, uvm_component parent); // creating constructor of monitor class
function void build_phase(uvm_phase phase); // Get interface reference from config database
if(!uvm_config_db#(virtual GUVM_interface)::get(this, “”, “GUVM_vif”, GUVM_vif)) begin
`uvm_error(“”, “uvm_config_db::get failed”)
Mon2Sb_port = new(“Mon2Sb”,this); // create port with scoreboard
/////////// monitor main task “converting signal into transaction then write to scoreboard” ////////////////
int count;
logic[31:0] mon_idata;
logic[31:0] mon_wdata;
logic[31:0] mon_instr;
logic[31:0] mon_addr;
//mon_wdata=GUVM_vif.data_wdata_o;
//GUVM_vif.OUTPUTDATA(mon_idata,mon_wdata,mon_instr,mon_addr);
processor_transaction pros_trans; // creating new sequence class with its constructor
pros_trans = new (“trans”);
count = 0;
//fork
forever begin @(GUVM_vif.OUTPUTDATA(mon_idata,mon_wdata,mon_instr,mon_addr)) // while there’s dataout from dut on the bus , monitor is operating
if(count<32) // counting on bits number of instruction inpit to dut
count++;
else
// pros_trans.wdata= mon_wdata; //Set transaction from interface data
	Mon2Sb_port.write(pros_trans); // writing data monitored into scoreboard
count=0;
//join
endtask:run_phase
endclass: GUVM_monitor
In reply to Randa:
Your scoreboard does not knwo anything about clock cyles. It knows only data in a specified order. You have to implement your monitor run_phase task to take care for this.
Okay, How could I manage that in monitor run phase as how to make that 5 clock cycle delay?
In reply to Randa:
You have simply to implement a counter counting up to 5. That’s it.
Okay, Thanks for the reply.
