How uvm phasing mechanism (behind the curtain) work ? can it be achived by systemverilog features?
In UVM we directly use phases to do different things. But how simulator understands from uvm base library that it need to start with build_phase and after that need to execute connect_phase and so on …
Till now I just got this info but don’t understand how it actually works. Could anyone help me understand summarizing underlying mechanism ?
https://verificationacademy.com/verification-methodology-reference/uvm/docs_1.1c/html/files/base/uvm_phase-svh.html#uvm_phase
In reply to vickydhudashia:
The simulator understands UVM because ir is written in SystemVerilog. The phasing is taking advantage of virtual methods and building lists of “Component” classes and simply iterating over that list for each phase. Below is a very simplified example showing the structures the UVM creates and how it executes them:
class Component;
  string m_name;
  Component m_parent;
  static Component list[$];
  function new(string name, Component parent);
    m_name = name;
    m_parent = parent;
    list.push_back(this);
  function string get_fullname;
    if (m_parent == null)
      return m_name;
    else
      return {m_parent.get_fullname(), "." , m_name};
  virtual function void build_phase;
  virtual task run_phase;
  virtual function void report_phase();
class A extends Component;
      super.new(name,parent);
     $display("A Constructing: ", get_fullname);
   task run_phase;
     #10  $display("Running   from ",get_fullname(),,$time);
   function void report_phase;
          $display("Reporting from ",get_fullname(),,$time);
class B extends Component;
   $display("B Constructing: ", get_fullname);
  A a;
    a = new("a",this);
  task run_phase;
    #20  $display("Running   from ",get_fullname(),,$time);
class Root extends Component;
    $display("env Constructing: ", get_fullname);
  A a;
  B b;
    a = new("a",this);
    b = new("b",this);
  task run_test;
    // build_phase
    for(int item=0;item<list.size();item++)
      list[item].build_phase();
    // run_phase
    foreach(list[item])
        int k = item;
        list[k].run_phase();
      join_none
    wait fork;
    // report phase
    foreach(list[item])
      list[item].report_phase();
module top;
   Root root;
     root =new("root",null);
     root.run_test();
