Hi.
I have a clocking block that i want to sync to its clock.
if i use @(cb) i usually get 1 cycle delay if when i get to this line in code it is during the clock posedge of this clocking block.
I would like to use “wait”. how can it be done ? (the clock is not in the list of the clocking block ins\outs)
Thanks !
In reply to snognogt:
You should show how your clocking block is defined.
You have 2 options.
using a clocking block or not. You cannot mix the approach.
Hi
It’s something like that :
interface my_if_t (input logic clk, reset);
logic read_done;
clocking mst_cb @(posedge clk);
input reset;
output read_done;
endclocking
clocking prb_cb @(posedge clk);
input reset,read_done;
endclocking
modport mst (clocking mst_cb);
modport prb (clocking prb_cb);
endinterface : my_if_t
And i would like to somewhere sync on the posedge clock of this block, but as i said if i make something like @(vif.mst_cb) i miss cycles since waiting for next change in the clocking block clock
Looks correct. Using a clocking block means you are always sync on a certain edge of your clock.Adgain, if you feel the clocking block is causing trouble you should not use it. Aclocking block is always an option.
