i am trying to implement the UVM testbench for dual port RAM with read and write operation of independent clocks.
How should i use two different agents for read and write operations with single sequence?
thanks
thanks
In reply to Niranjan Kumar N:
Each agent should have its own sequence. Here write agent should have a write sequence & read agent should have read sequence separately. The virtual sequence can be used to order the write & read sequences.
