in my testbench, code as follows, sometimes data_len is constrainted, max value more than 512 ,which isn’t expected!!,but simulator not report randomize failed!!, how to use soft in order to generate the designed packet payload length
class x_item extends uvm_sequence_item;
rand bit[15:0] data_len;
rand bit[31:0] x_data[];
calss my_seq extends uvm_sequence #(x_item);
rand my_pkt_enum my_pkt;
constraint C_data_len
(my_pkt==ether_pkt ) -> soft data_len >=0; soft data_len<= 512;
constraint C_xdata
x_data.size==data_len;
solve data_len before x_data;
virtual task body();
start_item(req)
if(!req.randomize with {
req.data_len==local::data_len;
`uvm_fatal("","" )
req.x_data=new[data_len];
foreach(x_data[i])
req.x_data[i]=x_data[i];
In my test ,sequence is randomized,when data_len is constrainted as specific value , Random results is right ,but use default constraint ,Uncertainly Random results occurs(may be more than 512),who can help me ? The simualtor is questasim10.2c.
class my_test0 extends uvm_test;
virtual task main_phase(uvm_phase phase );
my_seq my_seq_u=my_seq::type_id::create("my_seq_u");
// raise phase
if(! my_seq_u.randomize () with
my_pkt == ether_pkt;
data_len == 1230; // randomize result is right
`uvm_fatal("","")
class my_test1 extends uvm_test;
// raise phase
//data_len == 1230; default randomize result is uncertained.
`uvm_fatal("","")
thank u
./wszhong
