Hi , Can you please help for this
In the run phase i need to start parallel threads , can i create transaction with same name in all the parallel threads, if multiple threads got triggered then will it be overrided? if it is overrided can you please help me to solve this issue
if(intr_vif.controller_int_0_timeout) begin
intr_txn = interrupt_transaction::type_id::create("intr_txn");
intr_txn.controller_int_0_timeout = intr_vif.controller_int_0_timeout;
intr_txn.trans_num += 1;
`uvm_info("DATA FROM MON", $sformatf("DATA received from Interrupt MONITOR is : [%p] \n", intr_txn.controller_int_0_timeout),UVM_LOW)
ap.write(intr_txn);
if(intr_vif.ch1_controller_int_0_timeout) begin
intr_txn.ch1_controller_int_0_timeout = intr_vif.ch1_controller_int_0_timeout;
`uvm_info("DATA FROM MON", $sformatf("DATA received from Interrupt MONITOR is : [%p] \n", intr_txn.ch1_controller_int_0_timeout),UVM_LOW)
ap.write(intr_txn);
if(intr_vif.controller_int_0_ecc) begin
intr_txn.controller_int_0_ecc = intr_vif.controller_int_0_ecc;
`uvm_info("DATA FROM MON", $sformatf("DATA received from Interrupt MONITOR is : [%p] \n", intr_txn.controller_int_0_ecc),UVM_LOW)
ap.write(intr_txn);
if(intr_vif.ch1_controller_int_0_ecc) begin
intr_txn.ch1_controller_int_0_ecc = intr_vif.ch1_controller_int_0_ecc;
`uvm_info("DATA FROM MON", $sformatf("DATA received from Interrupt MONITOR is : [%p] \n", intr_txn.ch1_controller_int_0_ecc),UVM_LOW)
ap.write(intr_txn);
if(intr_vif.controller_int_0_lowpower) begin
intr_txn.controller_int_0_lowpower = intr_vif.controller_int_0_lowpower;
`uvm_info("DATA FROM MON", $sformatf("DATA received from Interrupt MONITOR is : [%p] \n", intr_txn.controller_int_0_lowpower),UVM_LOW)
ap.write(intr_txn);
if(intr_vif.ch1_controller_int_0_lowpower) begin
intr_txn.ch1_controller_int_0_lowpower = intr_vif.ch1_controller_int_0_lowpower;
`uvm_info("DATA FROM MON", $sformatf("DATA received from Interrupt MONITOR is : [%p] \n", intr_txn.ch1_controller_int_0_lowpower),UVM_LOW)
ap.write(intr_txn);
if(intr_vif.controller_int_0_rfifo_timeout) begin
intr_txn.controller_int_0_rfifo_timeout = intr_vif.controller_int_0_rfifo_timeout;
`uvm_info("DATA FROM MON", $sformatf("DATA received from Interrupt MONITOR is : [%p] \n", intr_txn.controller_int_0_rfifo_timeout),UVM_LOW)
ap.write(intr_txn);
if(intr_vif.ch1_controller_int_0_rfifo_timeout) begin
intr_txn.ch1_controller_int_0_rfifo_timeout = intr_vif.ch1_controller_int_0_rfifo_timeout;
`uvm_info("DATA FROM MON", $sformatf("DATA received from Interrupt MONITOR is : [%p] \n", intr_txn.ch1_controller_int_0_rfifo_timeout),UVM_LOW)
ap.write(intr_txn);
if(intr_vif.controller_int_0_training) begin
intr_txn.controller_int_0_training = intr_vif.controller_int_0_training;
`uvm_info("DATA FROM MON", $sformatf("DATA received from Interrupt MONITOR is : [%p] \n", intr_txn.controller_int_0_training),UVM_LOW)
ap.write(intr_txn);
if(intr_vif.ch1_controller_int_0_training) begin
intr_txn.ch1_controller_int_0_training = intr_vif.ch1_controller_int_0_training;
`uvm_info("DATA FROM MON", $sformatf("DATA received from Interrupt MONITOR is : [%p] \n", intr_txn.ch1_controller_int_0_training),UVM_LOW)
ap.write(intr_txn);
if(intr_vif.controller_int_0_userif) begin
intr_txn.controller_int_0_userif = intr_vif.controller_int_0_userif;
`uvm_info("DATA FROM MON", $sformatf("DATA received from Interrupt MONITOR is : [%p] \n", intr_txn.controller_int_0_userif),UVM_LOW)
ap.write(intr_txn);
if(intr_vif.ch1_controller_int_0_userif) begin
intr_txn.ch1_controller_int_0_userif = intr_vif.ch1_controller_int_0_userif;
`uvm_info("DATA FROM MON", $sformatf("DATA received from Interrupt MONITOR is : [%p] \n", intr_txn.ch1_controller_int_0_userif),UVM_LOW)
ap.write(intr_txn);
if(intr_vif.ch1_controller_int_0_misc || ch1_controller_int_0_bist || ch1_controller_int_0_crc) begin
intr_txn.ch1_controller_int_0_misc = intr_vif.ch1_controller_int_0_misc;
intr_txn.ch1_controller_int_0_bist = intr_vif.ch1_controller_int_0_bist;
intr_txn.ch1_controller_int_0_crc = intr_vif.ch1_controller_int_0_crc;
`uvm_info("DATA FROM MON", $sformatf("DATA received from Interrupt MONITOR is : [%p] \n", intr_txn),UVM_LOW)
ap.write(intr_txn);
if(intr_vif.controller_int_0_misc || controller_int_0_bist || controller_int_0_crc) begin
intr_txn.controller_int_0_misc = intr_vif.controller_int_0_misc;
intr_txn.controller_int_0_bist = intr_vif.controller_int_0_bist;
intr_txn.controller_int_0_crc = intr_vif.controller_int_0_crc;
ap.write(intr_txn);
if(intr_vif.ch1_controller_int_0_dfi || ch1_controller_int_0_dimm || ch1_controller_int_0_freq || ch1_controller_int_0_init) begin
intr_txn.ch1_controller_int_0_init = intr_vif.ch1_controller_int_0_init;
intr_txn.ch1_controller_int_0_dfi = intr_vif.ch1_controller_int_0_dfi;
intr_txn.ch1_controller_int_0_dimm = intr_vif.ch1_controller_int_0_dimm;
intr_txn.ch1_controller_int_0_freq = intr_vif.ch1_controller_int_0_freq;
ap.write(intr_txn);
if(intr_vif.controller_int_0_dfi || controller_int_0_dimm || controller_int_0_freq || controller_int_0_init) begin
intr_txn.controller_int_0_init = intr_vif.controller_int_0_init;
intr_txn.controller_int_0_dfi = intr_vif.controller_int_0_dfi;
intr_txn.controller_int_0_dimm = intr_vif.controller_int_0_dimm;
intr_txn.controller_int_0_freq = intr_vif.controller_int_0_freq;
ap.write(intr_txn);
if(intr_vif.controller_int_0_mode || controller_int_0_parity) begin
intr_txn.controller_int_0_parity = intr_vif.controller_int_0_parity;
intr_txn.controller_int_0_mode = intr_vif.controller_int_0_mode;
ap.write(intr_txn);
if(intr_vif.ch1_controller_int_0_mode || ch1_controller_int_0_parity) begin
intr_txn.ch1_controller_int_0_parity = intr_vif.ch1_controller_int_0_parity;
intr_txn.ch1_controller_int_0_mode = intr_vif.ch1_controller_int_0_mode;
ap.write(intr_txn);
join
######################################################################################################3
endtask : run_phase
