How to solve the issue about the output data in a task
task read_data(logic[31:0] addr, output logic [31:0] data);
   my_handle hdl;
   hdl.get_data(data);
class my_handle extends uvm_component;
  logic [31:0] buf[$];
  task get_data(output logic [31:0] data);
    wait(buf.size);
    data = buf.pop_front();
in my test, I tried to call the task read_data(), but it failed at below error.
Error-[AIORPML] Illegal argument to port
Argument to inout/output/ref port must be an expression that is valid on the left-hand side of a procedural assignment.
Please kindly give me a help. Thank you
In reply to zz8318:
It is not clear from your question which line is causing the error. Could it be the line that calls read_data() which you did not show?
Hi Dave, sorry for that. Let me paste the error line here.
in my test I created a task (named wait_to_idle) as shown below.
task my_test::wait_to_idle();
logic [31:0] data;
logic [31:0] addr = 'hxxxx;
read_data(addr, data); <== here is the error line
In reply to zz8318:
I see nothing wrong with the code you’ve shown. Check for typos.
I feel a little strange about the error information.
Does it mean we need to make sure that the argument tagged with the output direction is required to used in the left-hand side of assignment ?
In reply to zz8318:
Yes. The task does a procedural assignment to the actual output argument upon leaving the task.
So if you have
read_data(addr, somearg );
You must also be able to do
somearg = value;
I put the code " somearg = value " in another task which is inside class my_handle. Is that correct ??
wait(buf.size);
data = buf.pop_front(); <== here
In reply to zz8318:
No, I was referring to data in the task wait_to_idle
