Hi
probably some casting newbie question:
i have sequences inherit from a base sequence class which have a some field (int myint)
created a uvm_sequence_library from those sequence
i want to set this myint for all sequences of library - so i created a function in library to initiate it
but i get the following error during elaboration
Error-[MFNF] Member not found
file.sv, 60
“this.sequences[i].”
Could not find member ‘myint’ in class ‘uvm_object_wrapper’, at
“/foundary/software/synopsys/vcs/Q-2020.03-SP2/etc/uvm-1.2/base/uvm_factory.svh”,
Note - without this initialization process - seq_lib works great
Sequences and lib :
class my_base_sequence extends uvm_sequence #(some_type);
int myint;
class new_seq1 extends my_base_sequence ;
class new_seq2 extends my_base_sequence ;
class my_seq_lib extends uvm_sequence_library #(some_type);
function new (string name = "bs_400g_jtag_seq_lib");
add_typewide_sequence(new_seq1 ::get_type());
add_typewide_sequence(new_seq2 ::get_type());
init_sequence_library();
endfunction : new
function set_int();
foreach (sequences[i]) begin
sequences[i].myint = 3;
Test :
class my_test extends my_base_test;
my_seq_lib seq_lib;
seq_lib = my_seq_lib::type_id::create("seq_lib", this );
uvm_config_db#(uvm_sequence_base)::set(this, "my_env.m_vseqr.m_my_seqr.main_phase", "default_sequence", seq_lib);
seq_lib.selection_mode = UVM_SEQ_LIB_RAND;
seq_lib.print();
endfunction : build_phase
seq_lib.set_int();
seq_lib.start(..., null);
n.
