Shall I use import DPI_C like this ?
import “DPI-C” function void populate_mem_struct(input unsigned int data,input unsigned int address); ???
In reply to Nirmal Solomon:
SystemVerilog requires that you write “int unsigned”.
Note that your tool should provide a dpi header file to match the SystemVerilog prototype with the C prototype. Check your User Manual.
