Hi,all:
I want to do some register model operating in sequence ,but I have initial this register model in my top_env,I use virtual sequence to do this job,but nc tells me ,that the pointer of regmodel is null, maybe the regmodel is used before it constructed. I don’t konw how to describe this problem , so, here is my code .
my_reg.sv
`ifndef MY_REG
`define MY_REG
class my_ram extends uvm_mem;
function new(string name="n_ram");
super.new(name,`UVM_REG_ADDR_WIDTH'h400,32,"RW",build_coverate(UVM_NO_COVERAGE));
endfunction : build
`uvm_object_utils(my_ram)
endfunction : my_ram
class my_reg_block extends uvm_reg_block;
rand my_ram n_ram;
function new(string name = "regmodel");
super.new(name,build_coverage(UVM_NO_COVERAGE));
endfunction : new
this.default_map=create_map("",0,4,UVM_LITTLE_ENDIAN);
this.n_ram=my_ram::type_id::create("n_ram");
this.n_ram.build();
this.n_ram.configure(this,"n_ram.mem");
this.default_map.add_mem(this.n_ram,`UVM_REG_ADDR_WIDTH'h0,"RW",0);
endclass : my_reg_block
`endif
reg_tb.sv
`ifndef REG_TB
`define REG_TB
`include "my_config.sv"
`include "reg_req_lib.sv"
`include "ral_apb_reg_block.sv"
class reg_tb extends uvm_env;
`uvm_component_utils(reg_tb)
apb_env apb0;
my_config cfg;
my_reg_block regmodel;
reg_to_apb_adapter reg_sqr_adapter;
reg_to_apb_adapter mon_reg_adapter;
uvm_reg_predictor#(apb_transfer) reg_predictor;
super.new(name,parent);
endfunction:new
cfg=my_config::type_id::create("cfg");
apb0=apb_env::type_id::create("apb0",this);
uvm_config_object::set(this,"apb0*","cfg",cfg);
uvm_config_object::set(this,"slave[0]*","cfg",cfg.slave_configs[0]);
regmodel=my_reg_block::type_id::create("regmodel",,get_full_name());
regmodel.configure(null,"top.u_dut.apb_slave");
regmodel.build();
regmodel.lock_model();
regmodel.reset();
reg_sqr_adapter=reg_to_apb_adapter::type_id::create("reg_sqr_adapter",,get_full_name());
mon_reg_adapter=reg_to_apb_adapter::type_id::create("mon_reg_adapter",,get_full_name());
reg_predictor=new("reg_predictor",this);
endfunction : build_phase
regmodel.default_map.set_sequencer(apb0.master.sequencer,reg_sqr_adapter);
regmodel.default_map.set_auto_predict(1);
reg_predictor.map=apb_slave.default_map;
reg_predictor.adapter=mon_reg_adapter;
apb0.master.monitor.item_collected_port.connect(reg_predictor.bus_in);
endfunction:connect_phase
endclass : reg_tb
`endif
vsequencer.sv
class vsequencer extends uvm_sequencer;
`uvm_component_utils(vsequencer)
apb_master_sequencer apb_seq;
endclass:vsequencer
reg_seq_lib.sv
`ifndef REG_SEQ_LIB
`define REG_SEQ_LIB
`include "vsequencer.sv"
class my_reg_seq extends uvm_reg_sequence;
`uvm_object_utils(my_reg_seq)
function new(string name ="my_reg_seq");
endfunction : new
rand uvm_reg_addr_t addr;
rand uvm_reg_data_t data;
virtual task body();
uvm_status_e status;
if(starting_phase != null)
starting_phase.raise_objection(this,{"Running sequence '"get_full_name(),"'"});
addr=32'h0;
data=32'h1;
regmodel=my_reg_block::type_id::create("regmodel");
repeat(10) begin
regmodel.n_ram.write(status,addr,data,.parent(this));
addr++;
data += 32'h10;
starting_phase.drop_objection(this,{"Completed sequence '",get_full_name(),"'"});
endtask : body
endclass : my_reg_seq
class vsequence extends uvm_sequence;
`uvm_object_utils(vsequence)
`uvm_declare_p_sequencer(vsequencer)
my_reg_seq reg_seq;
function new(string name="vsequence");
endfunction : new
reg_seq=my_reg_seq::type_id::create("reg_seq");
reg_seq.regmodel=p_sequencer.regmodel;
reg_seq.start(null);
endtask : body
endclass : vsequence
`endif
reg_test_lib.sv
`ifndef REG_TEST_LIB
`define REG_TEST_LIB
`include "reg_tb.sv"
class reg_test extends uvm_test;
`uvm_component_utils(reg_test)
reg_tb reg_tb0;
vsequencer vsqr;
function new(string name ,uvm_component parent);
endfunction : new
reg_tb0=reg_tb::type_id::create("reg_tb0",this);
uvm_config_db#(uvm_object_wrapper)::set(this,"vsqr.main_phase","default_sequence",vsequence::type_id::get());
vsqr.regmodel=reg_tb0.regmodel;
endfunction : connect_phase
endclass :reg_test
`endif
What’s wrong with my code ,and how i modify it?
