in reference model
typedef bit[31:0] mda[4][16]
funtion mda calc_xxx(...);
mda data;
return data
I want to get the function return array in scb.
because mda is not an item , so can not pass it by PORT/EXPORT
in reference model
mda data;
return data
In reply to designer007:
Simply wrap the array inside a class extended from uvm_object. Then all you have to do is pass the handle to the object around.
