I want to pass design path from command line and want to use as hierarcy into my code.
Problem Statement,
From command line I will pass as “+PATH=TB_TOP.CHIP.BLOCK_A.BLOCK_B.CLK”
Now I would like to get this path using $value$plusargs function into my TB file.
For example,
string clk_sign;
void’($value$plusargs(“PATH = %s”,clk_sign));
@posedge(clk_sign);
$display($time);
As we are getting full path as string into clk_sign variable. I can not use directly as hierarcy path.
Is there any way we overcome this and convert this path from string format to actual design path.
OR
Any other suggestion to handle this scenario.
I am using VCS tool.
Pratik
