How do I make, my_env1.cfg1 to be visible and to be same as my_test.cfg1? (i.e whenever lower levels make changes to my_env1.cfg1, it will also be reflected on my_test.cfg1, or whenever the code within my_test writes to my_test.cfg1, it will also be reflected in my_env1.cfg1?
If you want to pass a configuration object from your env to the test you do not need the config_db, because there is a well-defined relationship between test and env.
In my_test you can simply write:
my_env my_env1;
cfg cfg1;
my_env1 = my_env::type_id::create("my_env1",this);
cfg1 = my_env1.cfg1;
Handle assignment will not work in build_phase() due to its top-down nature unless “cfg” is created in constructor of “env”. Or use above solution by chr_sue in connect_phase() of testcase.
You can also use configuration setting with these options,
cfg1 = cfg::type_id::create("cfg1",this);
uvm_config_db#(cfg)::set(null, "*", "c_cfg", this.cfg1); // Can get from any scope
//Or
uvm_config_db#(cfg)::set(uvm_root::get(), "*", "c_cfg", this.cfg1); // Can get from any scope
In reply to EE:
The assignmaent has been made after the construction of the env, i.e. the cfg object of the env is available.
Your suggestion means that I should update the build_phase within my_env?
Then, does this mean, in my_test, I should use uvm_config_db get with the same label?
If you do not say which configuration data you have in your config obejct there is no common answer. Configuration data influencing the generation of your testbenchave to be handled differently as configuration data with respect to sequences etc.
And there is another basic question: what is the reason you want to move-up configuration data from your env to your test. The objective of a test is to confiure your testbench, including your env in such a way you can verify a cerrtain functionality and not vice versa.
