In one of my UVM environment, I have 2 sequences, one interrupt service sequence and another normal packet sequence.
Here is the sequence of events:
At 0ns, pkt sequence started without grab. Driver takes 15ns to complete the transaction.
At 10ns, interrupt triggered. interrupt sequence has wait for interrupt event, followed by grab()
At 15ns, after the normal pkt finishes another pkt is initiated with grab()
At 16ns, another interrupt triggered.
In this scenrio I expected following sequence:
1 - pkt 1 finishes at 15ns
2 - first interrupt sequence starts at 15ns and finishes at 30ns
3- Now at 30ns, we have 2 pkts both with grab statments, normal pkt seqeunce with pkt 2 usign grab and interrupt sequence with second interrupt with grab()
4 – Since pkt 2 is initiated with grab first, it takes over and finishes. But I see that second interrupt is finishing first.
Here is the code:
`include “uvm_macros.svh”
interface intr_intf();
logic intr;
endinterface
class pkt extends uvm_sequence_item;
`uvm_object_utils(pkt)
function new(string name=“pkt”);
endclass : pkt
class intr_service_seq extends uvm_sequence;
`uvm_object_utils(intr_service_seq)
uvm_event intr_ev = uvm_event_pool::get_global(“intr_ev”);
function new(string name=“intr_service_seq”);
task body();
pkt m_pkt;
intr_ev.wait_on();
intr_ev.reset();
grab();
m_pkt = pkt::type_id::create(“m_pkt”);
start_item(m_pkt);
uvm_info(get_name(),"Servicing interrupt",UVM_LOW) finish_item(m_pkt);
uvm_info(get_name(),“Serviced interrupt”,UVM_LOW)
ungrab();
class pkt_sequencer extends uvm_sequencer#(pkt);
`uvm_component_utils(pkt_sequencer)
intr_service_seq m_intr_seq;
virtual intr_intf vif;
super.new(name,parent);
if(!uvm_config_db#(virtual intr_intf)::get(this,“”,“vif”,vif))
`uvm_fatal(“NO_INTF”, “CAN NOT GET THE INTF : INTR_INTF”)
m_intr_seq = intr_service_seq::type_id::create(“m_intr_seq”);
m_intr_seq.start(this);
join_none
@(posedge vif.intr);
intr_ev.trigger;
`uvm_info(get_name(),“Interrupt triggered”,UVM_LOW)
class driver extends uvm_driver#(pkt);
uvm_component_utils(driver) function new(string name, uvm_component parent); super.new(name,parent); endfunction task run_phase(uvm_phase phase); pkt m_pkt; super.run_phase(phase); forever begin seq_item_port.get_next_item(m_pkt);
uvm_info(“DRV”,$sformatf(“Drive Pkt”),UVM_LOW)
#15;
seq_item_port.item_done();
endclass : driver
class seq1 extends uvm_sequence#(pkt);
`uvm_object_utils(seq1)
int unsigned seq_num;
function new(string name=“seq1”);
task body();
pkt m_pkt;
uvm_info(get_name(),"Started Body",UVM_LOW) for(int i=0;i<10;i++) begin m_pkt = pkt::type_id::create("m_pkt"); if(i==1) grab(); start_item(m_pkt);
uvm_info(get_name(),$sformatf(“After Start Item pkt_num:%0d”,i),UVM_LOW)
m_pkt.randomize();
finish_item(m_pkt);
uvm_info(get_name(),"After Finish Item ",UVM_LOW) if(i==1) ungrab(); end
uvm_info(get_name(),“Ended Body”,UVM_LOW)
endclass: seq1
class test extends uvm_test;
`uvm_component_utils(test)
pkt_sequencer seqr1;
driver drvr;
seq1 m_seq1;
seqr1 = pkt_sequencer::type_id::create(“seqr1”,this);
drvr = driver::type_id::create(“drvr”,this);
m_seq1 = seq1::type_id::create(“m_seq1”);
drvr.seq_item_port.connect(seqr1.seq_item_export);
phase.phase_done.set_drain_time(this,100ns);
phase.raise_objection(this);
m_seq1.start(seqr1);
phase.drop_objection(this);
endclass : test
module tb_top;
intr_intf intr_if();
uvm_config_db#(virtual intr_intf)::set(uvm_root::get(),“*”,“vif”,intr_if);
run_test();
intr_if.intr = 0;
#10ns;
intr_if.intr = 1;
#5ns;
intr_if.intr = 0;
#1ns;
intr_if.intr = 1;
#2ns;
intr_if.intr = 0;
Here is the output:
UVM_INFO @ 0: reporter [RNTST] Running test test…
UVM_INFO test_interrupt.sv(100) @ 0: uvm_test_top.seqr1@@m_seq1 [m_seq1] Started Body
UVM_INFO test_interrupt.sv(106) @ 0: uvm_test_top.seqr1@@m_seq1 [m_seq1] After Start Item pkt_num:0
UVM_INFO test_interrupt.sv(81) @ 0: uvm_test_top.drvr [DRV] Drive Pkt
UVM_INFO test_interrupt.sv(66) @ 10: uvm_test_top.seqr1 [seqr1] Interrupt triggered
UVM_INFO test_interrupt.sv(109) @ 15: uvm_test_top.seqr1@@m_seq1 [m_seq1] After Finish Item
UVM_INFO test_interrupt.sv(33) @ 15: uvm_test_top.seqr1@@m_intr_seq [m_intr_seq] Servicing interrupt
UVM_INFO test_interrupt.sv(81) @ 15: uvm_test_top.drvr [DRV] Drive Pkt
UVM_INFO test_interrupt.sv(66) @ 16: uvm_test_top.seqr1 [seqr1] Interrupt triggered
UVM_INFO test_interrupt.sv(35) @ 30: uvm_test_top.seqr1@@m_intr_seq [m_intr_seq] Serviced interrupt
UVM_INFO test_interrupt.sv(33) @ 30: uvm_test_top.seqr1@@m_intr_seq [m_intr_seq] Servicing interrupt
UVM_INFO test_interrupt.sv(81) @ 30: uvm_test_top.drvr [DRV] Drive Pkt
UVM_INFO test_interrupt.sv(35) @ 45: uvm_test_top.seqr1@@m_intr_seq [m_intr_seq] Serviced interrupt
UVM_INFO test_interrupt.sv(106) @ 45: uvm_test_top.seqr1@@m_seq1 [m_seq1] After Start Item pkt_num:1
UVM_INFO test_interrupt.sv(81) @ 45: uvm_test_top.drvr [DRV] Drive Pkt
UVM_INFO test_interrupt.sv(109) @ 60: uvm_test_top.seqr1@@m_seq1 [m_seq1] After Finish Item
With this result, it looks like grab always puts the request at the beginning of queue. Even though there are other grabs present in the queue, latest grab will always be pushed to the front of the queue and the latest grab gets executed first-- such as last in first out.
Can anyone clarify if this understanding/behaviour is correct. Thank you very much in advance.
