Hi all,
Are there any way to know that uvm_config_db::set is execute successful?
Since if I adding wrong hierarchy path,simulator did not produce any error/warning, so it is hard to debug.
Thank you in advance!
Hi all,
In reply to SonNguyen:
uvm_config_db set does not check anything. You Can make a set to a hierarchy which does not exist. Only the type of the arguments will be checked. But with print_config you can print the settings for a component.
Thank you Chr_Sue, Dave for reply.
Your answer were helpful.
