Hi All,
I have top.sv, sequence_pkg.sv and test_pkg.sv
///////test_pkg.sv//////////
package test_pkg;
`include "uvm_macros.svh"
import sequence_pkg::*;
import env_pkg::*;
`include test1.svh //sequence1
`include test2.svh //sequence2
etc....
endpackage
//////////sequence_pkg.sv///////////
package sequence_pkg;
import mvc_pkg::*;
`include "sequence1.svh"
`include "sequence2.svh"
etc..
endpackage
///////////////////top.sv////////////////////
module top();
import test_pkg::*;
etc...
When I tried to run, I am getting error in top.sv file;
package test_pkg could not be bound.
I could not run any testcase test1.svh, test2.svh.
It results in common error. Can anyone please give hint, where I went wrong?
In reply to Mahesh K:
You need to compile package files with top module. Which all files are you compiling and with what command?
Based on error message , It seems to me compile ordering issue.
Please make sure test_pkg is compile before top module.
In reply to RonakShah:
Thank you all for the suggestions. There was one warning in the uvm constructor;
function new (string name “”);
endfunction: test6
For this, I was getting the error I mentioned and one warning saying “expecting new keyword”. Later I have modified the code;
endfunction: new
And I got the desired result.
In reply to MayurKubavat:
How to compile package before top module in EDA playground
- should i copy the package file and top module both in testbench.sv
In reply to yethishwar:
You need to ask this question on the EDAPlayground forum.
Okay dave , Thank you
