How to get env handle at scoreboard to get access to some function in env
I have a class(scoreboard) which needs to include a handle to another class (env) which is compiled later in the flow . they are in one package. Because scoreboard is compiled later than env, so there is compile error if I just write as below in scoreboard .
class scoreboard;
env my_env;
so how to do to get env handle in scoreboard?
thanks
In reply to blair:
For this situation there is the so called forward typedef.
Simply write in front of class scoreboard typedef class env.
typedef class env;
class scoreboard;
The question is where is your scoreboard in your topology? Is it outside of your env? This might not be a good idea.
hi,
chr_sue.
thank you for your solution.
for your question,
my scoreboard is in my env, due to inheritance development, i have to get env handle in scoreboard.
