How to generate multiple resets in virtual sequence during simulation
I have a specific requirement in the below code.
task normal_seq::body();
  reset_seq.start(null,this); // reset sequence
    normal_seq1.start(null,this); // sequences following reset sequence.
    normal_seq2.start(null,this);
    normal_seq3.start(null,this);
    normal_seq4.start(null,this);
    normal_seq5.start(null,this);
I wanted to have multiple resets during simulation with random delays. and if reset is detected, then normal_seq1 should start executing after each reset.
  repeat(5) begin
  #($urandom_range(25,20))
join
Problem is i am not finding a way to return my normal sequence flow to normal_seq1 each time reset is detected. Could you please suggest a way to do it.
In reply to 8Blades:
As per my understanding, you are wanting to generate reset randomly within you simulation and you wanted to start your normal_seqeunces from #1 to #5.
For this requirement
repeat(5) begin
  join_any
  disable fork;
From body task, you can do above thing, But this is not recommended, you should have implement your driver which can release your transaction (item_done) whenever it detects reset from interface.
