I have made a VIP for a DUT in UVM, but the problem i am facing is that there is wires in the interface( or DUT output wire) which changes according to the config parameter.
For eg For K =1 logic [SIZE_FOR_K1-1 :0]]mem_out_1; …only 1 wire
For K=2 :2 wires
logic [SIZE_FOR_K1-1 :0]]mem_out_1; ......2 wires of different width
logic [SIZE_FOR_K2-1 :0]mem_out_1;
and so on…
DUT files are generated using scripts according to the configuration.
Now How can I alter my verification environment, so that i dont have to generate different files of my environment for different configuration.
PLease reply as soon as possible
Thanks in advance.
This is how I might do it.
package param_test_pkg;
include "uvm_macros.svh" class default_test extends uvm_test;
uvm_component_utils(default_test)
super.new(name,parent);
class param_test #(int SIZE_FOR_K=0) extends default_test;
`uvm_component_param_utils(param_test#(SIZE_FOR_K))
$display("here\n");
endpackage
module dut();
parameter SIZE_FOR_K=1;
wire [SIZE_FOR_K-1:0] dut_wire;
module test();
localparam int SIZE_FOR_K=1;
import uvm_pkg::;
import param_test_pkg::;
dut #(SIZE_FOR_K) my_dut();
initial
default_test::type_id::set_type_override(param_test#(SIZE_FOR_K)::get_type());
run_test(“default_test”);
In reply to ktmills:
thanks for the reply…but the problem is that wire width alone doesn’t change …no of wires also changes according to the configuration… For e.g
if k=1 i have one wire of size =10 bits
if k=2 i have 2 wires
if k=3 i have 3 wires
and so on…
and these are output wires …so my monitor logic changes according to the no of wires of the DUT.
so wat can i do for this problem, whether to generate the code of monitor through the scripts or something else …
Please reply soon
thanks in advance
In reply to rishabh:
interface dut_interface #(SIZE_FOR_K=1) ();
wire [SIZE_FOR_K-1:0] [7:0] A;
genvar i;
generate
for(i=0; i<SIZE_FOR_K; i=i+1) begin : loop1
assign A[i][7:0] = my_dut.loop1[i].A[7:0];
endgenerate
endinterface
`include "uvm_macros.svh"
`uvm_component_utils(default_test)
typedef virtual interface dut_interface #(SIZE_FOR_K) dut_vif_t;
dut_vif_t dut_vif;
if(uvm_config_db#(dut_vif_t)::get(null, "dut_if", "dut", dut_vif) == 0)
`uvm_fatal("NULL_INTERFACE","dut interface for 'dut' has not been registered with the uvm_config_db")
for(int i=0; i<SIZE_FOR_K; i++)
$display("value of dut_vif.loop[%0d].A: 0x%0x",i,dut_vif.A[i][7:0]);
endpackage
module dut();
genvar i;
generate
wire [7:0] A = i;
endgenerate
module test();
localparam int SIZE_FOR_K=4;
import param_test_pkg::*;
dut #(SIZE_FOR_K) my_dut(.*);
bind dut dut_interface #(SIZE_FOR_K) dut_if(.*);
initial
uvm_config_db#(virtual interface dut_interface #(SIZE_FOR_K) )::set(null, "dut_if", "dut", my_dut.dut_if);
run_test("default_test");
thanks a lot …but 1 thing if u have taken fixed size of wires of 8 bit …but if i want to make it also configurable of different width how can i do it ???
