I am looking for a way that dynamically change the base class, can somebody give me a hint?
Without plugin code,
The uvm_object hierarchy looks like this:
C ← B ← A ← uvm_object
In testcase, using factory_override, B_type override A_type.
In command line, using C_type override B_type by using +uvm_set_type_override=A,C
It works fine that A2 is created as an C type instance.
Now I want to plugin a piece of code to constrain B, with minimal change(don’t change factory_override in the test), is it possible to get the C type instance applied BB constraint? In other words, I want to get a C type instance, whose pkt_type is IPV6.
So far, I tried to use +uvm_set_type_override=B,BB +uvm_set_type_override=A,C. But it didn’t work.
module tb;
`include "uvm_macros.svh"
class A extends uvm_object;
rand bit[7:0] pkt_len;
constraint pkt_len_c {
pkt_len inside {[1:10]};
`uvm_object_utils_begin(A)
`uvm_field_int(pkt_len, UVM_ALL_ON)
`uvm_object_utils_end
function new(string name="A");
endfunction // new
endclass // A
typedef enum {ETH, IPV4, IPV6} pkt_type_e;
class B extends A;
rand pkt_type_e pkt_type;
A A_obj;
constraint b1_cs {
pkt_type == IPV4;
`uvm_object_utils_begin(B)
`uvm_field_enum(pkt_type_e, pkt_type, UVM_ALL_ON)
`uvm_field_object(A_obj, UVM_ALL_ON)
function new(string name="B");
endfunction // new
A_obj = A::type_id::create("A");
endfunction // build_phase
endclass // A
// PLUGIN CODE
class BB extends B;
constraint b1_cs {
pkt_type == IPV6;
`uvm_object_utils(BB)
function new(string name="BB");
endfunction // new
endclass // BB
// PLUGIN CODE END
class C extends B;
rand bit ocs_en;
`uvm_object_utils_begin(C)
`uvm_field_int(ocs_en, UVM_ALL_ON)
function new(string name="C");
endfunction // new
endclass // C
class test1 extends uvm_test;
A A1, A2;
`uvm_component_utils(test1)
function new(string name="test1", uvm_component parent);
endfunction // new
`uvm_info(get_full_name(), ", full_path:", UVM_LOW)
factory.set_type_override_by_type(A::get_type(), B::get_type(), 0);
factory.print();
A2 = A::type_id::create("A2");
assert(A2.randomize());
A2.print();
endclass // test1
initial run_test("test1");
