I am trying to develop Memory VIP.In which i have requirement like to drive Command as well As data parallel.
requirements:
- Need to receive packets for both row and column command bus,as well as need to drive respective packets on respective bus at same time.
2)if row packets come and no packets for column, then need to drive row packet on row bus as well as same time i need to drive no packet(Specific bit Pattern like NOP)on column and vice versa.And if no packets arrived for both at that time i need to drive NOP on both the bus for both edge positive and negative.Overall if packet is available then need to drive it else always NOP on bus.
in short i Want to develop develop logic such that both row and column bus work interdependently but at same time.
I am unable to figure it how to develop logic according to my requirement.
Can Anyone give me idea how to develop it…!!
Any Sample Code or Examples.!!
Regards,
Harsh
In reply to harsh pandya:
It would be easier to understand your requirement clearly if you could mention some piece of code for the packet transaction class and bus interface signal details.
In reply to karan_18:
class mc_driver_c extends uvm_driver#(mem_seq_item_c);
// Internal variables dclaration //
bit [2:0] wl; // Write latecy
bit [4:0] rl; // read latecy
bit par; // Parity Field
bit bl; // burst length
bit ps_no; // Pseudo no
event row_e,col_e;
// Row And Column Command Queue //
mem_seq_item_c row_pkt_q[$]; // Queue To Store Row Packets
mem_seq_item_c col_pkt_q[$]; // Queue To Store Column Packets
// Virtual interface //
virtual mem_intf.driver mc_driver_vif;
// Agent Configuration class handle //
mc_agent_config_c driver_cfg_h;
// Analysis port declaration //
uvm_analysis_port #(mem_seq_item_c) drv_port_mc_ps_0;
uvm_analysis_port #(mem_seq_item_c) drv_port_mc_ps_1;
// component registration //
`uvm_component_utils(mc_driver_c)
// Constructor //
function new (string name,uvm_component parent);
super.new(name,parent);
drv_port_mc_ps_0 = new("drv_port_mc_ps_0",this);
drv_port_mc_ps_1 = new("drv_port_mc_ps_1",this);
endfunction :new
// Build phase //
void'(uvm_config_db#(mc_agent_config_c)::get(this,"","mc_driver_config"
,driver_cfg_h));
if(!uvm_config_db#(virtual mem_intf )::get(this,"","mem_intf"
,mc_driver_vif))begin
`uvm_fatal("NOVIF",{"virtual interface must be set for: ",get_type_name()
,".mc_driver_vif"});
endfunction :build_phase
// run phase //
mem_initilization();
get_item();
row_pkt_collector();
col_pkt_collector();
join
endtask : run_phase
// Initilization //
virtual task mem_initilization();
bit [5:0] ra;
bit [7:0] ca;
`uvm_info(get_type_name(),
$sformatf("--[ : mem Initilization Start : ]--"),
UVM_MEDIUM)
$sformatf("--[ : mem Initilization Done: ]--"),
UVM_MEDIUM)
endtask : mem_initilization
// Driver Packet receive from sequencer //
virtual task get_item();
seq_item_port.try_next_item(req);
if(req == null)begin
if((row_pkt_q.size() == 0) && (col_pkt_q.size() == 0))begin
rnop_cnop_comb_driver();
end else if(row_pkt_q.size() > 0)begin
cnop();
end else begin
rnop();
end else begin
//Storing Packet According to Command
if(req.cmd_e inside {RD,WR})begin
mem_seq_item_c col_pkt;
$cast(col_pkt,req.clone());
col_pkt_q.push_back(col_pkt);
-> row_e;
end else begin
mem_seq_item_c row_pkt;
$cast(row_pkt,req.clone());
row_pkt_q.push_back(row_pkt);
-> col_e;
//Sending to score board
$sformatf("--[ : %s PKT Arrived In Driver : ]--",req.cmd_e.name()),
UVM_LOW)
if(req.pseudo_no == 0)begin
req.dir="TX";
drv_port_mc_ps_0.write(req);
$sformatf("--[ : Driver Sent %s PKT To SB In PS%d : ]--",
req.cmd_e.name,req.pseudo_no),
UVM_LOW)
end else begin
req.dir="TX";
drv_port_mc_ps_1.write(req);
UVM_LOW)
@(negedge mc_driver_vif.ck_t)
seq_item_port.item_done();
endtask : get_item
// Row Packet COllector //
virtual task row_pkt_collector();
while(1)begin
wait(row_e.triggered);
if(row_pkt_q.size > 0)begin
mem_seq_item_c pkt_r;
pkt_r = row_pkt_q.pop_front();
row_cmd_create(pkt_r);
#1ns;
endtask : row_pkt_collector
// Column Packet COllector //
virtual task col_pkt_collector();
while(1)begin
wait(col_e.triggered);
if(col_pkt_q.size > 0)begin
mem_seq_item_c pkt_c;
pkt_c = col_pkt_q.pop_front();
col_cmd_create(pkt_c);
#1ns;
endtask : col_pkt_collector
//Other Respective task
hear is code. but is not working like my requirement.
The packet which is sent to scoreboard(via analysis port) should be collected from what is actually being driven on the DUT interface(i.e from the monitor using the virtual interface handle) and not from what is received from sequencer.
end else begin
drive_column_pkt(req);
end else begin
drive_row_pkt(req);
//This task should drive the DUT interface signals as per the protocol
task drive_column_pkt(...);
task drive_row_pkt(...);
If it is still not working, please show the code where the interface signals are driven.
end else begin
end else begin
drive_row_pkt(req);
Hi Karan,
thank you…!!
packets are coming from sequencer …!!
yes its driving on interface…!!
here issue is not with packet…packets are coming proper manner…!!
but the issue is if i got separate packets for row and column bus i want to drive simultaneously on interface.so basically i need to check is there any packet in other queue.if yes then i need to drive both simultaneously. or if not then need to drive that packet on reactive bus and need to drive nop on other bus.
right now its works but issue is if i have packet inside both row and column queue…my driver is driving those packets one by one not bot at same time.
so my question is what are the changes required to achieve my requirement…!!
and one more thing vip is not connected with dut i am just checking how driver is driving.
