How to do multiple instance of same agent?
Hi All,
I’m new to UVM. i have created 5 agents ,5 interfaces and the interfaces are set in top module. while passing the different sequence to agent1 (interface intf[1]),agent3(interface intf[3] and channel agent (interface ch_if) all the agents have same result.i think all the interfaces are overriding or config set and get has issue.
Please help me to resolve this issue.
top module:
gen_if intf [4];
gen_if ch_if;
generate
  for(genvar i=0;i< 4;i++) begin
      uvm_config_db#(virtual gen_if)::set(null,"*","vif",intf[i]);
endgenerate
initial
    uvm_config_db#(virtual gen_if)::set(null,"*","vif",ch_if);
Driver code:
if(!uvm_config_db#(virtual gen_if)::get(this,"","vif",driverif))
      `uvm_fatal("NOIF", {"interface must be set for: ", get_full_name(),".driverif"});
In reply to amsaveni.c:
Since there are Multiple Instances , one way would be to add a property in class
driver ::
int  inst_id ;  //  To  be  set  when  create()  is  called  for  driver  i.e  From  agent
Your top_module would also have to include the Instance Number with ‘field_name’ ::
generate
      uvm_config_db#(virtual gen_if)::set(null,"*", $sformatf("vif[%0d]" , i ) , intf[i]);
endgenerate
 //   Within  Agent's  build_phasse()  ::
 for( int i=0;i< 4;i++) begin
 driver_h[i] = driver :: type_id :: create( $sformatf( "driver_h[%0d]" , i )  , this )  ;
 driver_h[i].inst_id  =  i ;
// Within  Driver's   build_phase()  ::
if(!uvm_config_db#(virtual gen_if)::get(this,"", $sformatf("vif[%0d]",inst_id ),driverif ))
      `uvm_fatal("NOIF", {"interface [%0d] must be set for: ",  inst_id , get_full_name(),".driverif"});
You need to provide the path to each specific agent in your uvm_config_db#()::set instead of using a wildcard “*”. You can quickly find out what the paths should be by commenting out the set() statements and seeing the path generated by get_full_name in the `uvm_fatal message.
top module:
gen_if intf [4]();
gen_if ch_if();
  initial uvm_config_db#(virtual gen_if)::set(null,
                                              $sformatf("uvm_top_test.MyEnv.MyAgent%0d",i),
                                              "vif",
                                              intf[i]);
initial uvm_config_db#(virtual gen_if)::set(null,"uvm_top_test.MyEnv.MyAgent4","vif",ch_if);
Thank you for your valuable response. but your code is only work out for gen_if intf [4]; if i use gen_if ch_if(); parallely its not working.
while am passing specific agent path to config_db,the output of the all agent is similar to last agent( channel agent).but i passed different sequence to all the agent. the result should be different for each agent.
please provide any suggestion for this case.
Please see below. This code works. Adding the
check_config_usage()
shows the writes and the reads.
module top;
`include "uvm_macros.svh"
gen_if intf [4]();
gen_if ch_if();
  initial
    uvm_config_db#(virtual gen_if)::set(null, $sformatf("uvm_top_test.MyEnv.MyAgent%0d",i), "vif", intf[i]);
  uvm_top.check_config_usage();
Hey all,
I’m having the same issue, i want to instantiate one agent more than one time. I made my agent vif parametrizable, in agent level, I created one drv and one sequencer, and the env level, I instatited the agent as many times as needed then pass the coresponding vif to each agent. But when i try to assert/deassert a signal only for one instance, it gets asserted/deasserted for all agents.
Do you guys know what should i do ?
In reply to abdelaali_21:
Looks like you have only 1 SV interface in the tolevel module.
Could you please show some relevant code (related to the structure/topology).
Indeed, I created agent for that protcol in which i created its interface, drv, mtr, seqr. Imade this agent interface paramterizable. then in env i intantiated three agent from the agent i created. But the issue is when i want to assert a sig of a specific interface among these three interfaces it gets asserted for all interface. Note that, the assertion of that signal is done in run phase inside a block of fork join with protcol process.
You did not answer my question. How many SV interfaces of the same type does your toplevel module have.
See code snippets above.
i have intatiated 1 sv interface three times
some pseudo here;
in tb top
ahb_if ahb_if0;
ahb_if ahb_if1;
ahb_if ahb_if2;
OK. Looks good.
And your DUT has 3 different ahb interfaces.
How do you pass them to the config_db?
in top i set vif
uvm_config_db#(virtual ahb_if)::set(null,““,“ahb_if0”, ahb_if0);
uvm_config_db#(virtual ahb_if)::set(null,”
”,ahb_if1", ahb_if1);
uvm_config_db#(virtual ahb_if)::set(null,“*”,ahb_if2", ahb_if2);
How are these interfaces connected to the DUT?
Or do you have no DUT.
In my case I have no DUT
This is nor a problem. You can have the interface instances in your toplevel testbench. But ypu need the config_db calls for connecting these interfaces to the agents/drivers/monitors.
