Hi all,
I have a test in which two sequences A and B are called on separate virtual interfaces to DUT. Inside scoreboard - a reference model produces correct output only after sequence A is done. I would like to start monitor only after sequence A is done. I know roughly how long it takes for sequence A to finish. sequence A is only called once during test. Can I set a bit in my monitor and control it from test? Any other suggestions?
In reply to gupadhya:
Roughly is not accurate neough. Simply trigger an event when sequence A has been finished and start with the execution in the monitor.
class adc_uvc_monitor extends uvm_monitor;
`uvm_component_utils(adc_uvc_monitor)
event rif_seq_done;
virtual adc_uvc_if mladc_adc_if;
adc_mon_item mladc_mon_item;
uvm_analysis_port #(adc_mon_item) item_collected_port_adc;
function new(string name="adc_uvc_monitor", uvm_component parent);
super.new(name,parent);
endfunction : new
item_collected_port_adc = new("item_collected_port_adc", this);
endfunction : build_phase
if (!uvm_config_db #(virtual adc_uvc_if)::get(null, "*", "adc_uvc_vif", this.mladc_adc_if)) begin
`uvm_error("connect", "ADC virtual interface not found")
mladc_mon_item = adc_mon_item::type_id::create("mladc_mon_item", this);
endfunction : connect_phase
@(posedge mladc_adc_if.rst_n);
wait(rif_seq_done.triggered);
`uvm_info(get_type_name(), $sformatf("About to start ADC monitor\n"), UVM_NONE);
monitor();
join_none
@(negedge mladc_adc_if.rst_n);
disable fork;
endtask : run_phase
task monitor();
@mladc_adc_if.cb2;
mladc_mon_item.data_p = mladc_adc_if.cb2.data_p;
mladc_mon_item.vin_n = mladc_adc_if.cb2.VIN_N_S;
mladc_mon_item.vin_p = mladc_adc_if.cb2.VIN_P_S;
item_collected_port_adc.write(mladc_mon_item);
Inside sequence I am doing -
`uvm_info(get_type_name(), $sformatf(“Triggered rif_seq_done\n”), UVM_NONE);
->uvm_test_top.mtop_tb_env_h.adc_env_h.agent_h.adc_monitor_h.rif_seq_done;
Getting elab error -
xmelab: *E,CUVUNF (/prj/analog/ace_ip_tsmc22nm/sandiego/work_v100/gunjanu_mladc_2/design_project/verif_modules/verif/sim/tests/autoseq_tests/sequence_lib/src/mladc_rif_seq.sv,144|76): Hierarchical name component lookup failed at ‘uvm_test_top’.
So question is how do I trigger event inside monitor from a sequence?
The error message is correct. The sequence does not know anything about your testbench topology.
I recommend to use the uvm_event instead of the simple SV event together with the uvm_event_pool. This solves the probelm with the topology.
