//Sequence
class fifo_write_sequence extends uvm_sequence#(fifo_seq_item);
`uvm_object_utils(fifo_write_sequence)
`uvm_declare_p_sequencer(fifo_write_sequence)
function new(string name="fifo_write_sequence");
virtual task body();
fifo_seq_item seq;
while(p_sequencer.fun()!=1)begin
seq=new();
start_item(seq);
assert(seq.randomize()with{seq.wr==1;});
finish_item(seq);
//Sequencer
class fifo_sequencer extends uvm_sequencer#(fifo_seq_item);
`uvm_component_utils(fifo_sequencer)
uvm_analysis_imp#(fifo_seq_item, fifo_sequencer) mon_imp;
fifo_seq_item trans;
bit full;
function void write(fifo_seq_item trans);
full=trans.wr_full;
super.new(name,parent);
function bit fun;
return full;
When I try accessing function from sequencer into sequence using p_sequencer then I get error that member not found. Please help me solve this error.
