How to disable sequencer using uvm_config_db?
I want to disable my sequencer from test. So I used uvm-config_db to SET “count” to zero. But the sequencer is not disabled. How to disable it?
class test2_dis_sub extends base_test;
        uvm_config_db#(int)::set(this, “env.eth_agent.sqr”, “count”, 0); // using this I want to disable the sqr
         eth_pkt_seq e_seq = eth_pkt_seq::type_id::create ("e_seq");
         super.run_phase(phase);
         phase.raise_objection (this);
         ... // there are other sequences run by other sequencers, which i am not showing here
         e_seq.start (env.eth_agent.sqr); // sqr is the sqr handle, expecting this sqr to be disabled, but not happening, how to disable ?
         phase.drop_objection (this);
class eth_sqr extends uvm_sequencer#(eth_pkt); // sequencer code
	int count;
	`uvm_component_utils_begin(eth_sqr)
	   `uvm_field_int(count, UVM_ALL_ON);
	`uvm_component_utils_end
	function new (string name="eth_sqr", uvm_component parent=null);
		super.new(name,parent);
In reply to rakesh2learn:
The OVM method of using ‘count’ to control a sequencer was deprecated by UVM and can not be used. The correct method is to not call start on your sequence.
The run_phase() is usually unique for each test and will start only the sequences required for that test.
In reply to cgales:
Thanks for your reply. As you suggested I don’t use ‘start’. I do as shown below.
	uvm_config_db#(int)::set(this, "env.eth_agent.sqr", "count", 0);
        uvm_config_db#(uvm_object_wrapper)::set(this,"env.eth_agent.sqr.main_phase", "default_sequence", eth_pkt_seq::type_id::get());
The sequencer is still active and I get output from this sequencer, but it is supposed to get disabled. But it is not happening, why ?
As cgales said, using count to switch-off is a deprecated construct in UVM.
It might not be supported in future versions of UVM.
In your case I’d set the default sequence to the run_phase of your sequencer and not on the to the main_phase.
You are still ‘starting’ the eth_pkt_seq on the sequencer. You moved the starting of the sequence from:
to:
Both of the above options will ‘start’ the sequence on the sequencer. Do not include the lines above and the sequencer will not run the eth_pkt_seq sequence.
So what is the alternative to ‘count’ so I can disable sequencer in UVM ?
In reply to dhserfer:
Obviously if I don’t include those sequence , it won’t run. But, the idea behind my question is to disable the sequencer even though the sequence is started. Like how ‘count’ is used to work in OVM.
One option is to use the start/finish mechanism and make it dependet on a control object.
