How to disable assertion in side uvm object from test
I am looking for way to disable assert in side uvm component for certain test. Bellow simple code represent my env, with comment for requirement. I thought i can use $assertoff. I can modify uvm component if required additional instrumentation to achieve this. Thanks,
`include "uvm_macros.svh"
class tb_env extends uvm_component;
   `uvm_component_utils(tb_env)
   int exp_val = 0;
   int act_val = 0;
   function new(string name = "tb_env", uvm_component parent = null);
   virtual task run_phase (uvm_phase phase);
     super.run_phase(phase);
     phase.raise_objection(this);
     #10us;
     ASRT: assert ( exp_val == act_val) else
       `uvm_error(get_name(), "Error");
     #10us;
     `uvm_info(get_name(), "Done env", UVM_LOW);
     phase.drop_objection(this);
   endtask : run_phase
program tb_run;
initial
   tb_env env = new("env");
   // Requirement: Disable assertion env.ASRT with system call $assertoff(...)
     run_test();
      #5us;
      env.exp_val = 1;
   join
endprogram
In reply to albert.waissman@intel.com:
see 16.4.4 Disabling deferred assertions in the SV Standard.
