How to derive a register name from regmodel
Hello,
I need to read/write and apply different methods on my register model, however I am unable to get access simultaneously to different registers with the same name.
e.g: In my sequence I need to get the mirrored value of REGx with x = 1 … 30
and in my regmodel ,each of these registers is instantiated separately, so every time I need to write in or read these registers ,I need to call them one by one .
is there any better way to do this,because it is really inconvenient for large number of registers.
In reply to verif_25:
Hello,
You could try to play around with the uvm_re (regular expressions) to get all the registers in your model that match a specific pattern (keep in mind you need to have DPI enabled when compiling the UVM library and UVM regex uses POSIX AFAIK)
For example given the following register and reg model:
`include "uvm_macros.svh"
class my_reg extends uvm_reg;
 `uvm_object_utils(my_reg)
    rand uvm_reg_field f1;
    function new (string name = "");
      super.new(name, 8, UVM_NO_COVERAGE);
    function void build;
      f1 = uvm_reg_field::type_id::create("f1");
      f1.configure(this, 8, 0, "RW", 0, 0, 1, 1, 0);
class my_reg_model extends uvm_reg_block;
    `uvm_object_utils(my_reg_model)
    // A register model containing two registers
    rand my_reg r0;
    rand my_reg r1;
    rand my_reg r30;
  	rand my_reg rX;
      super.new(name, build_coverage(UVM_NO_COVERAGE));
      r0 = my_reg::type_id::create("r0");
      r0.build();
      r0.configure(this);
      r0.add_hdl_path_slice("r0", 0, 8);      // name, offset, bitwidth
      r1 = my_reg::type_id::create("r1");
      r1.build();
      r1.configure(this);
      r1.add_hdl_path_slice("r1", 0, 8);      // name, offset, bitwidth
      r30 = my_reg::type_id::create("r30");
      r30.build();
      r30.configure(this);
      r30.add_hdl_path_slice("r30", 0, 8);      // name, offset, bitwidth
      rX = my_reg::type_id::create("rX");
      rX.build();
      rX.configure(this);
      rX.add_hdl_path_slice("rX", 0, 8);      // name, offset, bitwidth
      default_map = create_map("my_map", 0, 3, UVM_LITTLE_ENDIAN); // name, base, nBytes
      default_map.add_reg(r0,  0, "RW");  // reg, offset, access
      default_map.add_reg(r1,  1, "RW");  // reg, offset, access
      default_map.add_reg(r30, 2, "RW");  // reg, offset, access
      default_map.add_reg(rX,  3, "RW");  // reg, offset, access
      lock_model();
You could implement the logic somewhere in your sequence etc
module test();
  bit match;
  string regex = "r[0-9]+";
  my_reg_model  regmodel;
  uvm_reg reg_list[$];
  uvm_reg reg_list_to_be_written[$];
    regmodel = my_reg_model::type_id::create("regmodel");
    regmodel.build();
    regmodel.print();
    regmodel.get_registers(reg_list);
    foreach(reg_list[i]) begin
      match = uvm_re_match(regex, reg_list[i].get_name());
      if(!match) begin // zero means match
        `uvm_info("TEST", $sformatf("reg = %s found with regex = %s", reg_list[i].get_name(), regex), UVM_LOW)
        reg_list_to_be_written.push_back(reg_list[i]);
    do_stuff(reg_list_to_be_written);
    $finish;
   task automatic  do_stuff (ref uvm_reg regs[$]);
    uvm_reg_data_t mirror_value;
    foreach(regs[i]) begin
      mirror_value = regs[i].get_mirrored_value();
      `uvm_info("TEST", $sformatf("reg = %s mirrored value = %0h",  regs[i].get_name(), mirror_value), UVM_LOW)
Which outputs:
# KERNEL: ---------------------------------------------------
# KERNEL: Name        Type           Size  Value
# KERNEL: regmodel    my_reg_model   -     @445
# KERNEL:   r0        my_reg         -     @447
# KERNEL:     f1      uvm_reg_field  ...    RW r0[7:0]=8'h00
# KERNEL:   r1        my_reg         -     @451
# KERNEL:     f1      uvm_reg_field  ...    RW r1[7:0]=8'h00
# KERNEL:   r30       my_reg         -     @455
# KERNEL:     f1      uvm_reg_field  ...    RW r30[7:0]=8'h00
# KERNEL:   rX        my_reg         -     @459
# KERNEL:     f1      uvm_reg_field  ...    RW rX[7:0]=8'h00
# KERNEL:   my_map    uvm_reg_map    -     @463
# KERNEL:     endian                 ...   UVM_LITTLE_ENDIAN
# KERNEL:     r0      my_reg         ...   @447 +'h0
# KERNEL:     r1      my_reg         ...   @451 +'h1
# KERNEL:     r30     my_reg         ...   @455 +'h2
# KERNEL:     rX      my_reg         ...   @459 +'h3
# KERNEL: UVM_INFO /home/runner/testbench.sv(85) @ 0: reporter [TEST] reg = r0 found with regex = r[0-9]+
# KERNEL: UVM_INFO /home/runner/testbench.sv(85) @ 0: reporter [TEST] reg = r1 found with regex = r[0-9]+
# KERNEL: UVM_INFO /home/runner/testbench.sv(85) @ 0: reporter [TEST] reg = r30 found with regex = r[0-9]+
# KERNEL: UVM_INFO /home/runner/testbench.sv(97) @ 0: reporter [TEST] reg = r0 mirrored value = 0
# KERNEL: UVM_INFO /home/runner/testbench.sv(97) @ 0: reporter [TEST] reg = r1 mirrored value = 0
# KERNEL: UVM_INFO /home/runner/testbench.sv(97) @ 0: reporter [TEST] reg = r30 mirrored value = 0
You can find more information about UVM re here
HTH,
-R
