Hi Verification Academy ,
I want to demote all uvm error to uvm warning in on of my agent. I see example for disabling for specific Error Code - But i just want to disable it entirely for a specific hierarchy. What is the best approach for this ?
In reply to manikandansriram:
When I mean a component , For instance when I want to set to an agent ,I want all the uvm errors demoted into uvm warning in all its class members too like the driver,monitor,sequencer etc.
You can do this from the command line
<sim command> +uvm_set_severity=uvm_test_top.env0.*,ALL,UVM_ERROR,UVM_WARNING
Or you can use set_report_severity_id_verbosity_hier() from your test after the build_phase is complete.
