My reference model has to subscribe to N number of monitors of same class. If I have to use imp port to connect N monitors analysis exports, Is there any way I can do that in minimum amount of code or I have to declare write imp port for each of N subscriptions separately?
This is what my reference model has as of now,
// file : ref_model.sv
`uvm_analysis_imp_decl(_rcvd_1)
`uvm_analysis_imp_decl(_rcvd_2)
`uvm_analysis_imp_decl(_rcvd_N)
class my_reference_model extends uvm_component
Is it possible to declare these rcvd_1 to rcvd_N imp ports with some loop to reduce number of lines?
In reply to MilanKubavat:
this is not possible, consider use tlm_fifo array instead
In reply to Yuankun:
Yes. That’s my plan B. Just wanted to know if there was any way with imp port.
Thanks for the response Yuankun.
What is point of using array if you can’t implement write method. instead use macro define.
write``_rcvd_1()
In reply to nitin62goel:
You can declare an array of uvm_tlm_analysis_fifo instances, and each instance implements a write() method. Then you need a process that does a get() of all the instances, or a set of process that do a get() on each instance. Which way you choose depends on what your requirements are.
