Hi All,
As I know, there are 2 ways of implementing sequencer.
way of using `uvm_declare_p_sequencer(), So I can use “p_sequencer” to start sequence.
way of using sequencer’s hierachy name to start sequence.
When I check “null” value as below, There was no compilation problem.
if( base_ahb_seq == null)
`uvm_info(get_type_name(),"!!!!!!!!!!!!!NO base_ahb_seq!!!!!!!!!!!!!!!!", UVM_LOW)
if( p_sequencer.masterSeqr1 != null)
base_ahb_seq.start(p_sequencer.masterSeqr1);
else
`uvm_info(get_type_name(),"!!!!!!!!!!!!!NO seqr!!!!!!!!!!!!!!!!", UVM_LOW)
But I’m stuck on getting *E,TRNULLID: NULL pointer dereference error when I ran UVM code…
How do I know “P_SEQUENCER” was correctly implemented or not? ( I know, it’s not recommaned way of using “p_sequencer”. But that uvm was made from other user’s UVC. and I have to use it in my side)
