Any one please suggest me how to create regAdapter for pipelined protocol like AHB.
Saravanan
Saravanan
In reply to saravanan_kpk:
I belive nothing to be taken care in regAdapter. the driver should have the capability
Hello, saravanan_kpk.
I hope I understand your intention correctly.
You can use uvm_reg_frontdoor instead:
class smt_ahb_burst_frontdoor extends uvm_reg_frontdoor;
ahb_transaction bus_access;
task body();
int access_number = my_method_to_count_access(rw_info);
for (int access_index = 0; access_index < access_number; access_index++) begin
bus_access = my_method_to_create_ahb_access_from_reg_item(rw_info, access_index);
`uvm_send(bus_access)
get_response(rsp);
my_method_to_analyze_response(rw_info, rsp);
function int my_method_to_count_access(uvm_reg_item rw_info);
my_method_to_count_access = 0;
if(rw_info.kind inside {UVM_READ, UVM_WRITE})
my_method_to_count_access = 1;
else if(rw_info.kind inside {UVM_READ, UVM_WRITE})
my_method_to_count_access = rw_info.value.size();
Best regards, Maksim.
