How to create parallel frame sending and receiving in UVM, with single agent
Dear Forum,
I have a master and slave style protocol, where the communication is full duplex with different wires.
That means master can send data and in parallel it can receive data from slave. And of course the slave can send data based on master request, together with its other data sending. Usually in normal mode slave constantly measures and sends data to master.
May question is how to model Slave using UVM.
I want to use 1 agent to keep my code simple. But the issue is driver- sequence communication.
When my UVC is slave, than UVC should sends it data and in parallel it should track the master. And if master sends request slave should know this in parallel.
I think this cannot be done this using REQ, RSP mechanism, like make slave2master as REQ and master2slave as RSP.
But this will not work because when sequence sends REQ at the same time master may send frame i.e. driver should send RSP to sequence, interrupting REQ. Which is wrong in point of the protocol
In reply to haykp:
You should run in the drivers run_phase 2 processes in a fork/join, 1 for driving the data to the slave and the 2nd to receive the data coming from the slave.
I think it wont work
assume driver got the data from the slave while driving the data.
Than how driver can send that data to sequence?
RSP will not work as REQ still in process and takes time to finish.
In reply to haykp:
Which scenario do you have? Is it in-order, pipelined or out-of-order.
If you are driving some thing then the rsp you are observing is initiated by a privious drive and not fron the actual one.
It is out-of-order.
I agree about the rsp.
But the thing is in my case there is a req i.e. Sequence->driver and in parallel I need Driver->Sequence communication.
In UVM way only RSP carries transaction from Driver->Sequence, but this does not work for my case. Because RSP is a response of previous REQ, which means first REQ and than RSP. I need in parallel
In reply to haykp:
Is this the right order of req/rsp. There is an offset between req and rsp.
In reply to haykp:
Agree!#
But I need rsp to be in parallel or earlier than req
In reply to haykp:
Other option can be that monitor tracks the slave and when slave has some info to send, monitor generates transaction and broadcast by analyses port.
And sequence get that info from that analyses port.
In reply to haykp:
How do you get a rsp earlier than the req was sent? Sounds a little bit magic.
BTW you cannot send transaction from a monitor to a sequence through an analysis port. But you can sent it to the sequencer. Finally this is complicated compared to the solution with sequencer/driver.
Actually this is what I want to do. This is my target.
Why I cannot send traffic from monitor to sequence using analyses port?
By the way - do you agree that there is no other way to send independent traffic from driver to sequence?
In reply to haykp:
You can use analysis ports only with components, existing permanently. A sequence has a limited lifetime.
How do you get a rsp without a req? How is this working?
The drivers run_phase should look like this:
         seq_item_port.get(req);
         // dive the req
         // collect your rsp
         seq_item_port.put(rsp);
   join
Your code looks interesting.
And how to be when req is done, but rsp is still not.
Imagine the case driver service the req and send seq_item_port.put(rsp) to tell the sequence that req is done.
And than driver cannot collect rsp any more.
May I ask you please share how looks like the code in sequence?
I expect again in the sequence 2 parallel process - 1 send Req and another gets RSP.
And I agree about sequence stuff, that’s why I need forum opinion.
In reply to haykp:
In the sequence it looks like this:
task body();
   start_item(req);
   req.randomize();    // naybe you have to add constraints
   finish_item(req);
   get_response(rsp);
Maintaining the driver code is just easy.
Working with req and rsp means there is always a rsp belonging to a certain req. This defined by the seq_item_id.
How this is working in your environemnt I do not know.
Thanks for the code.
Well I think in the sequence the rsp always comes after req. It is not possible to have get_responce(rsp) than finish_item(req). It is not supported by UVM.
So that means driver cannot send data to sequence, it can only respond to sequence requests.
Now I am thinking to update sequencer which can take transactions from driver and send to sequence in separate analyses port.
In reply to haykp:
I believe I did not fully understand what your requirements are. Could you please share some more information, a drawing or some structural code through my email
christoph@christoph-suehnel.de
