How to copy the same 'pkt_id' on all 4 sequences?
Hi All,
I have the following where I want to randomize “pkt_item” and send it on 4 different sequences from my virtual sequence. When I randomize, for the first sequence, both pkt_id and data are randomized. For the other 3 sequences, I need to randomize only data; in other words, all 4 sequences will send a pkt_item with the SAME pkt_id but random data. How can I do this?
class pkt_item extends uvm_sequence_item;
  `uvm_object_utils(pkt_item)
  rand bit[7:0] pkt_id;
  rand bit[63:0] data;
class my_virt_seq extends uvm_sequence#(pkt_item);
  `uvm_object_utils(my_virt_seq)
  my_sequence_0 seqA;
  my_sequence_1 seqB;
  my_sequence_2 seqC;
  my_sequence_3 seqD;
  virtual task body();
    //factory create the sequences here; code not shown
    fork begin
      seqA.start(SEQRA);
      seqB.start(SEQRB);
      seqC.start(SEQRC);
      seqD.start(SEQRD);
    join
In reply to Verif Engg:
I guess you want to use your own ID (pkt_id).In that case your seunce has to have a data mamber which corresponds to pkt_id.
After the creation of the seuences you can assign the pakt_id to the corresponding data member.
Where is the problem?
All 4 sequences create and randomize pkt_item. However, for the B, C, D sequence, after randomization, pkt_id should be the same as sequenceA pkt_id. How would I copy pkt_id info across sequences?
Simply add an inline constraint to the randomize method with the same value for each pkt_id.
You can try this way,I assumed pkt_h as a handle to pkt_item type of object in your sequences my_sequence_0 , my_sequence_1 etc
     seqA.randomize() with {pkt_h.pkdid == 20;};
     seqB.randomize() with {pkt_h.pkdid == 20;};
     seqC.randomize() with {pkt_h.pkdid == 20;};
     seqD.randomize() with {pkt_h.pkdid == 20;};
    fork begin
      seqA.start(SEQRA);
      seqB.start(SEQRB);
      seqC.start(SEQRC);
      seqD.start(SEQRD);
    join
