How to connect scoreboard with more than one monitor
hi everybody,
In my env class , there is a master agent and slave agent.
and i want to connect master agent monitor and slave agent monitor to scoreboard.
The query i am having is :
  1. do i need to create two scoreboard for connecting two monitors.
  2. and how can i give defination for two write function , one write function for master agent monitor and second write for slave agent monitor .
Please help me for the above question.
In reply to Manirama:
I think you not need to create two scoreboard.
You can follow below steps.
  1. declare analysis port inside Master agent monitor.
uvm_analysis_port #(seq_item) master_mon2scb;
  1. declare analysis port inside Slave agent monitor.
uvm_analysis_port #(seq_item) slave_mon2scb;
3)declare 2 analysis imp to get monitor transaction inside your scoreboard.
`uvm_analysis_imp_decl(_master_mon2scb)
`uvm_analysis_imp_decl(_slave_mon2scb)
uvm_analysis_imp_master_mon2scb#(seq_item,scb) m_mon2scb;
uvm_analysis_imp_slave_mon2scb#(seq_item,scb) s_mon2scb;
//create both port
function write_master_mon2scb( seq_item m_tr );
function write_slave_mon2scb( seq_item s_tr );
  1. connect inside connect phase of your environment.
m_agent.mon.master_mon2scb.connect(env.scb.m_mon2scb);
s_agent.mon.slave_mon2scb.connect(env.scb.s_mon2scb);
I hope it helps.
Harsh
hi everybody,
You did not explain what you want to compare and a few other details of your UVM environment, like the seq_items do you have a master and a seperate slave seq_item?
See the Advanced UVM video course: How TLM Works or the UVM Cookbook for how to do this.
In reply to harsh pandya:
If we need to connect 8 monitors to single scoreboard ,then 8 write() functions need to implement in scoreboard class ,Any other way to optimize instead of writing 8 write() functions ??
In reply to dddvlsique:
As shown in Advaned UVM/How TLM Works, there are two ways to do this. The problem is that the write() call from an analysis_port supports 1:many calls, but not many:1 calls. So, while a single monitor can be connected to multiple scoreboards, the only way to connect a single scoreboard to multiple monitors is to have multiple analysis_exports(/imps) in your scoreboard.
The first method, as you surmised, is to create multiple implementations of write() in the scoreboard using the `uvm_analysis_imp_decl() macro.
`uvm_analysis_imp_decl(_BEFORE)
`uvm_analysis_imp_decl(_AFTER)
class score extends uvm_component;
  `uvm_component_utils(score);
  uvm_analysis_imp_BEFORE #(tr, score) before_export;
  uvm_analysis_imp_AFTER #(tr, score) after_export;
  virtual function void write_BEFORE(tr);
  virtual function void write_AFTER(tr);
The other alternative is to use uvm_tlm_analysis_fifos to provide the exports and therefore the write methods:
class score2 extends uvm_component;
  `uvm_component_utils(score2);
  uvm_analysis_export #(tr) b4_export;
  uvm_analysis_export #(tr) after_export;
  uvm_tlm_analysis_fifo #(tr) b4_fifo,after_fifo;
  function void connect_phase( uvm_phase phase );
    b4_export.connect(b4_fifo.analysis_export);
    after_export.connect(after_fifo.analysis_export);
    b4_fifo.get(t1);
    after_fifo.get(t2);
Note that in this second case, you need a run_phase() method to actively pull the data from the fifos.
