Hi
I have a DUT having multiple slave interfaces which are controlled by parameter.
I have created a Master UVC.
how to instantiate(create object) connect my Master UVC to DUT’s slave interfaces based on the parameter .
In that case how can I handle UVCs monitor analysis port connections with scoreboard based on Parameter
SaraM.
In reply to sachan451:
You need a lot more explanation. What kind of parameter, and how are the slave interfaces controlled by that parameter?
Hi Dave,
My DUT is MMU(memory management unit) and supports multiple DMA interfaces.
The number of DMA interfaces is controlled by parameter.
I prepared a DMA UVC to address an interface.
I have to connect it to DUT based on the Parameter.
SaraM.
