How the code works if i declare variable before factory registration
Hello, sir
I saw third-party’s testbench declare variable before using factory macro.
Some documents guide coding-style factory macro need to be used top of code.
Is there any difference between A and B?
-A-
class A extends uvm_object;
uvm_reg reg_common[$};
`uvm_object_utils(A)
-B-
In reply to hyunseok bang:
It doesn’t matter, but style -B- is preferable since it makes it easier to match up the class name A with the macro argument. Even more preferable when using parameterized classes.
Note that if you use the field automation macros, you must declare the field variables before the macro.
