How to check a signal for 20 clock cycle within a sequence
How to check that a signal if occur will last for 20 cycles within a sequence?
i.e @(posedge vif.clk) if(vif.a==1’b1) then vif.b should be 1’b0 for 20 cycles.
In reply to suvendra kumar sahoo:
This is better written as a simple assertion inside your interface
assert property (( @posedge clk) a |-> !b[*20]);
You need a $rose(a) if “a” is not a single pulse.
Ben Systemverilog.Us
