Hi.
I want to do something like this in my testcase
top.dut.block_a.mem.do_backdoor_wr();
I am not able to do this as we can not do hierarchical access from package and all.
Is there any alternative way for this ?
Hi.
In reply to irshad_mansur:
See The Missing Link: The Testbench to DUT Connection | Technical Paper | Verification Academy
Hi Dave,
I have gone through the paper in the link, it talks about the connection of DUT and TB. I understand that we can connect the DUT and TB ports by that way and make it accessible from TB.
but my query is how can we call function which is there deep down in DUT ?
In reply to irshad_mansur123:
Below is the simplest approach. The paper shows how you could use bind to insert many of these if the concrete class needs to go in many places in the hierarchy.
package test;
`include "uvm_macros.svh"
interface class backdoor_api;
pure virtual function void do_backdoor_wr();
// pure virtual function void do_backdoor_rd();
class test extends uvm_test;
`uvm_component_utils(test)
backdoor_api api_h;
super.new(name,parent);
if (!uvm_config_db#(backdoor_api)::get(this,"","api",api_h))
`uvm_fatal("NOAPI","API handle not set")
api_h.do_backdoor_wr();
endpackage
module testbench_top;
import test::backdoor_api;
class concrete extends uvm_object implements backdoor_api;
function new(string name);
concrete api_h = new("api_h");
uvm_config_db#(backdoor_api)::set(null,"*","api",api_h);
run_test("test");
module top;
dut dut();
module dut;
block block_a();
module block;
memory mem();
module memory;
$display("%m doing backdoor write");
Hi Dave ,
Is backdoor_api a standard defined api in uvm,
or we have to define it
