Hi
Is there way to print out what is inside uvm_config_db? I want to know what has been set in the uvm_config_db.
Thanks.
John
Hi
Thanks.
John
check_config_usage(1); // checks which resource has been set and never been used
print_config( bit recurse = 0, bit audit = 0 ); // Prints the configuration at the hierarchy level
If you want to see the full state of the uvm_config_db try inserting:
uvm_config_db #(int)::dump();
in your code. That will reveal the full content.
Also modern debuggers try and show this information in GUI. You need to run till “start_of_simulation_phase” though.
For instance in VCS-DVE one can see it under: The UVM dialog box. From menu click Trace → Debug UVM
HTH
Ajeetha, CVC
In reply to mperyer:
but where to write this??
how my log file will print after writing this??can you give me the example?
You can get more information on uvm_config_db from
Hope this helps
-BR
Hash
