I’m struggling to find a way to print the UVM RAL hierarchy? Ideally, I want the UVM RAL to print all uvm_reg_block, the uvm_reg in each uvm_reg_block and the detailed information associated with each uvm_reg e.g. field name/field width/register address etc.
Does anyone know if there is a built-in function (or some other ways) in the UVM RAL that can print out these information?
Kind regards,
Po
