How can I drive complex input in DUT?
How can I drive complex input in DUT? Can I generate that complex input using reference model that generated input drive in DUT using driver?
Is there any another possibility?
Please give me best suggestions
In reply to rahul pawar:
What do you mean with ‘complex input’. A DUT has pads/pins which are relating to wires (not Verilog wire). There is nothing complex.
hello sir,
I am trying to verify Ethernet receiver it’s input is 1bit mdi. that mdi is represent complete encoded Ethernet frame.
So how can I generate that mdi and drive to the DUT ?
Can you please suggest what should be my strategy to drive complex input?
7byte(preamble),1byte(SFD),6byte(destinations address),6byte(source address),2byte(payload length),46to1500byte(payload),4byte(CRC)
my input is derivative to this frame (i mean that 1bit mdi is complete encoded to this frame)
so I have to drive lots of 1bit-mdi for 1-package. and it’s to complex and difficult to debugging.
sir please give me suggestions for it. how can i drive complex input to DUT?
can I use uvm_subscriber for generate that complex input?
You should watch the videos here
https://verificationacademy.com/courses/uvm-basics
to understand how you can go ahead
