Search form
Main menu
My Account Menu
How to add header and payload bytes in a transaction class?
swapnilm
swapnilm
Full Access
Dear all,
I am trying to add 2 header bytes to payload bytes, in order to calculate the CRC which is based on the calculation of header and payload bytes and using polynomial (x^16 + x^12 + x^5 + x). I need to add the crc to the transaction packets.
The payload bytes are created by dynamic array method. When I try to add the 2 header bytes with dynamic array bytes for the calculation of CRC, it gives error. Can some one plz tell me how to add the 2 header bytes with payload bytes? plz find below the portion of code. Plz have a look at it and give me suggestion.
Code is as follows:-
`include "uvm_macros.svh"
class transaction extends uvm_sequence_item;
   rand bit [7:0] sync;
   rand bit [7:0] sof;
   rand bit [15:0] header;
   rand bit [7:0] payload[];
   rand bit [15:0] crc;
   rand bit [7:0] eof;
  constraint data_size_c { payload.size inside { [1 : 10]};};
    endfunction : new
   function [15:0] cal_crc;
        int j;
        bit [7:0]data;
        bit [15:0] n;
        bit [7:0] N[];
        reg [15:0] newcrc;
     n = header;
     N = n + payload;
      for ( j = 0; j <= N ; j++)
         bit [15:0] crc;
         reg [7:0] d;
         reg [15:0] c;
         //reg [15:0] newcrc;
       //  begin
         d = data[j];
         c = crc;
         newcrc[0] = d[4] ^ d[0] ^ c[8] ^ c[12];
         newcrc[1] = d[5] ^ d[1] ^ c[9] ^ c[13];
         newcrc[2] = d[6] ^ d[2] ^ c[10] ^ c[14];
         newcrc[3] = d[7] ^ d[3] ^ c[11] ^ c[15];
         newcrc[4] = d[4] ^ c[12];
         newcrc[5] = d[5] ^ d[4] ^ d[0] ^ c[8] ^ c[12] ^ c[13];
         newcrc[6] = d[6] ^ d[5] ^ d[1] ^ c[9] ^ c[13] ^ c[14];
         newcrc[7] = d[7] ^ d[6] ^ d[2] ^ c[10] ^ c[14] ^ c[15];
         newcrc[8] = d[7] ^ d[3] ^ c[0] ^ c[11] ^ c[15];
         newcrc[9] = d[4] ^ c[1] ^ c[12];
         newcrc[10] = d[5] ^ c[2] ^ c[13];
         newcrc[11] = d[6] ^ c[3] ^ c[14];
         newcrc[12] = d[7] ^ d[4] ^ d[0] ^ c[4] ^ c[8] ^ c[12] ^ c[15];
         newcrc[13] = d[5] ^ d[1] ^ c[5] ^ c[9] ^ c[13];
         newcrc[14] = d[6] ^ d[2] ^ c[6] ^ c[10] ^ c[14];
         newcrc[15] = d[7] ^ d[3] ^ c[7] ^ c[11] ^ c[15];
         $display("The value of CRC result newcrc = %h ",newcrc);
         return newcrc; //result;
    endfunction : cal_crc
   function void post_randomize();
          crc =  cal_crc();
    endfunction : post_randomize
    `uvm_object_utils_begin(transaction)
       `uvm_field_int(sync, UVM_ALL_ON|UVM_NOPACK)
       `uvm_field_int(sof, UVM_ALL_ON|UVM_NOPACK)
       `uvm_field_int(header, UVM_ALL_ON|UVM_NOPACK)
       `uvm_field_array_int(payload, UVM_ALL_ON|UVM_NOPACK)
       `uvm_field_int(crc, UVM_ALL_ON|UVM_NOPACK)
       `uvm_field_int(eof, UVM_ALL_ON|UVM_NOPACK)
    `uvm_object_utils_end
Any help would be appreciated,
Swapnil
Answers
dave_59
dave_59
Forum Moderator
Can you please tell us what the error is, and give us the complete testcase to save the readers on this forum the time to solve your problems.
Comments on this answer
Dear sir,
I am getting following errors when I tried to add header bytes to the payload bytes in order to calculate CRC which is dependent on both header(2 bytes) and payload bytes.
Errors are:- Error: transaction.sv(30): Illegal operation on unpacked types
Error: transaction.sv(30): Cannot assign a packed type to an unpacked type.
So can you plz tell me how to defeat this error as I really need to add the header bytes to the payload bytes.
Help is appreaciated.
Swapnil
OK, so the statement N = n + payload; is giving you trouble?
Can you give an example of values for n and payload and what the result should be? Did you really mean mathematical "addition" or do you mean "concatenation"?
How do expect the statement for ( j = 0; j <= N ; j++) to loop since N is an array, not an integer? You have a return statement inside your loop so the loop only executes once. Where does data get its value?
Swapnil,
Based on your description it looks like you need to first put header as 2 elements in the new "N" array, followed by "payload".
If so, try the following:
        int j;
        bit [7:0]data;
        bit [15:0] n;
        bit [7:0] N[];
        reg [15:0] newcrc;
     n = header;
     N = new [this.payload.size + 2]; // 2 more for header
     N = { >> {n, payload} };
     `uvm_info ("CVC-Dbg", $sformatf("header + payload: %p", N), UVM_MEDIUM);
      for ( j = 0; j < N.size ; j++)
i.e. use streaming operator >> - works fine for simple data types.
HTH
Ajeetha, CVC
www.cvcblr.com/blog
Hello Ajeetha Madam,
Thank you so much for your suggestion. It has helped in solving my problem. So I replaced data[j] with N[j] as an input byte to calculate the CRC. Thats correct, right?
Also I put return newcrc outside the for loop and not inside the for loop? Because it gives different crc values. So In order to calculate the crc value for each byte of N[j] , its better to put return newcrc outside the For loop, right? Please correct me if I am wrong.This is how I did it as shown below:-
int j;
bit [7:0]data;
bit [15:0] n;
bit [7:0] N[];
reg [15:0] newcrc;
n = header;
bit [15:0] crc;
reg [7:0] d;
reg [15:0] c;
d = N[j]; // data[j];
c = crc;
//return newcrc;
return newcrc;
crc = cal_crc();
Please correct me if I am wrong mam?
I appreciate your help,
Swapnil
Swapnil,
I believe you want to do c = newcrc; each time through the loop. Otherwise c is always 0. There is no need to do N =new[...];. Anytime you assign an array to dynamic array, the dynamic array is automatically re-sized to fit. Also, it would really help to format your code to make it more readable
class packet;
     bit [15:0]     m_header;
     rand bit [7:0] m_payload;
     bit [15:0]     m_crc
function bit [15:0] cal_crc;
       bit [7:0] N[];
       bit [15:0] newcrc;
       N = { >> {m_header, m_payload} };
      foreach(N[j])
         bit [7:0]  d = N[j];
         bit [15:0] c = newcrc;
       return newcrc;
          crc =  cal_crc();
endclass : packet
