Hello,
I have a reactive sequence that runs forever reacting to DUT’s behaviour. But, this sequence also needs information based on activity from other interfaces and from virtual sequence which coordinates all the sequences while running stimulus. My plan was to set this information in the config object of the agent, which has the sequencer on which the reactive sequence runs. Can I access env config object or config object other agents from the virtual sequence?
The config object’s are created and set into config db from env config object, which in turn gets created from the base test.
Is there any other bettor method to set the config objects of various agents from virtual sequence?
Madhu
